how i can do pass the light in an interior
User avatar (Default)
perspectivista
good afternoon where configured in octanerender to reveal the light beam that crosses the glass material is within the perspective ?
someone can help me ? i'm new in this software and i'm using the demo version, i'm waiting for authorization in the site for buy it
thank you so much
kubo
The current version does not support direct light thru transparent materials (such as glass), indirect gets calculated thou. But it'll be implemented pretty soon. Meanwhile you can use HDRIs to light your scene or take two pictures, one without the glass and another with it and blend both together.
perspectivista
thanks for replying, then how is that the images that the gallery post on render octane is alo the passage of light? that end like this done? or is that even if I buy the original software can not have this effect of light inside of my scenes?
best regards
vagos21
kubo meant this:
1. you have to delete the glass from the windows windows in your 3D editing software, export and render it without windows
2. render the same thing with windows and blend them in photoshop or something
perspectivista
thank you so much for reply, i will that to see what happen and i will upload the image to be criticized
perspectivista
i been did a couple image, first without sun passing and the second without windows and now i see the sun beam
Uploaded with ImageShack.us
i hope criticized
vagos21
Looks sweet! make some materials, turn on the "smooth" on them, and try again
maybe spoil us with a pathtracing render? i guess you have some more power than most of us with the 2 GPUs :D
radiance
in many cases you don't even see a reflection on the glass in the window as it's far too bright outside,
so just render with no glass in it ?
Radiance
perspectivista
thanks for responding to this follow-up questions, the detail is that I used the beta program and I can not make use of certain features of it, I tried to go in and buy a license and not allow me to access the page to acquire octanerender and get better.
the other thing is that when I try to put a texture to an object in 3d just applies to all elements sudece not understand why, because each element is properly modeled and mapped to program 3ds max and export it does not pass textures of the same, I think that being a trial version.
thank you for your comment, keep trying to login and buy a license.
regards
kubo
perspectivista wrote:when I try to put a texture to an object in 3d just applies to all elements
This usually is due to wrong obj export settings, check this thread for the exact values for your host app http://www.refractivesoftware.com/forum ... f=21&t=362
Return to “Works In Progress”
