OctaneRender® for Maya® v1.16b beta [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
This is the quick-fix release.
  • Batch render issue workaround.
DOWNLOAD
OctaneRender for Maya v1.16b beta (35.6MB autoinstaller file)
Yours,
The OctaneRender™ Team.
TBFX
Thanks JimStar, All seems to be working here.
T.
renmaxhb
Thanks,JimStar.
TBFX,
The plugin has maps number limit?
TBFX
renmaxhb wrote:TBFX, The plugin has maps number limit?
Yes, search the forum there are plenty of posts detailing these. The limits are different if you have a 5 series GPU (Fermi) or a 6 series (kepler).
There is also feedback on how many of each type of map you have in your scene in the render stats at the bottom of the render view within the Maya plugin.
T.
renmaxhb
TBFX, thanks a lot.
Hi,JimStar,
I foud a prioblem,When I set animation mode to "camera only",or "Movable proxies", batchrender can not load the animation of Material evrey frame.
Set the animation mode to "full" ,the plugin can render the animation of Material. But "full" bacthrender load all mesh of the scence evrey frame.It is slowly.
So when anmiantion mode set to "camera only"or "Movable proxies" ,it is usefull if plugin can load the animation of Material evrey frame.Like render a animation of water!
renmaxhb
TBFX,
some skill can solve this?
the MB:
water_t.rar
(19.09 KiB) Downloaded 251 times
arh-osa
I noticed by accident, that sometimes Month and Day attrs take a value of float numbers (in IPR mode). It doesn't affect the picture, though.
Here is an extraction from Maya's history:
setAttr "octaneSunSky.Day" 29;
setAttr "octaneSunSky.Day" 28;
setAttr "octaneSunSky.Month" 9;
setAttr "octaneSunSky.Day" 29.421053;
setAttr "octaneSunSky.Month" 8;
setAttr "octaneSunSky.Day" 24;
setAttr "octaneSunSky.Hour" 13.136842;
setAttr "octaneSunSky.Day" 20;
setAttr "octaneSunSky.Day" 17;
setAttr "octaneSunSky.Hour" 14.4;
setAttr "octaneSunSky.Hour" 15.410526;
setAttr "octaneSunSky.Month" 7.6;
setAttr "octaneSunSky.Day" 22;
setAttr "octaneSunSky.Day" 19;
setAttr "octaneSunSky.Day" 13;
setAttr "octaneSunSky.Month" 5;
setAttr "octaneSunSky.Day" 16;
setAttr "octaneSunSky.Hour" 12;
setAttr "octaneSunSky.Day" 14.894737;
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
charge
I have a strange issue since upgrading from OctaneRender for Maya v1.13 beta to this version. In the previous versions, when I render an image, I get frequent updates in the render view showing me the progress of the render. In 1.16b, I get a single update at the beginning of the render, and then only when the render is complete do I get another screen refresh showing me the final image. This is all using the Render View window to render a single frame from within Maya.
Intel Core 2 Quad Q6600 (Kentsfield) @ 2.4ghz. Asus P5N-E SLI (nForce 650i). 8GB ram. 6GB Geforce Titan + 2GB GeForce GTX 560 Ti. Win 7 x64.
arh-osa wrote:I noticed by accident, that sometimes Month and Day attrs take a value of float numbers (in IPR mode). It doesn't affect the picture, though.
It's funny.:lol:
But it is how Maya's "attrControlGrp" UI element works - it is inside Maya, there is nothing to do from the plugin's side to change this weird thing... Plugin just uses this Maya's API command to show the Node's integer attribute in the attribute editor UI...
Anyway, I've just double-checked it - the integer value itself is set correctly in this case (if you will try to "getAttr" after this strange float setting - you will see that the integer value of the attribute is correct)...
renmaxhb wrote:TBFX, thanks a lot.
Hi,JimStar,
Thanks for report.
I will add this feature to the next version soon...
Return to “Autodesk Maya”
