OctaneRender® for Maya® v1.16 beta [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
  • New 1.16 engine..
  • Fixed the bug which caused materials attached to wrong meshes in some rare cases.
  • Minor bug fixes...
DOWNLOAD
OctaneRender for Maya v1.16 beta (35.6MB autoinstaller file)
Yours,
The OctaneRender™ Team.
renmaxhb
Good,thanks!
1.16 is faster than 1.14,but batchrender can not work in some scences .
TBFX
Thanks JimStar,
This version seems quite unstable for me. I've attached some crash logs. Most of these occurred when I stopped an IPR session, made a minor change and then tried to start another IPR session. It didn't seem to matter what I changed. A couple of the crashes also happened when adjusting attribute sliders while an IPR session was active.
T.
Edit: Most of these happened while setting up the fog example scene in that I have posted here
http://render.otoy.com/forum/viewtopic.php?f=28&t=32848
MayaCrashLogs_130527.zip
(614.81 KiB) Downloaded 220 times
Thank you.
Will check it.
Next version HERE.;)
Return to “Autodesk Maya”
