Hi for now I use GTX Titan + GTX560ti 1GB
when Im Using for render this two cards .Octane use 1Gb memory of 560ti
If I will change 560ti 1GB for gtx780 3GB
Will octane use 6gb of Titane memory or 3GB of gtx780?
What´s the best way ?
Thank you!
GtxTiTan 6gb + GTX780 3gb
there are several options:
* first. leave only titan to render /then You'll have full 6gb of cards vram for Your renders.
* or buy second one, & You'll cut Your times /a little will be used for monitor though
with 780 You'll be limited to 3gb.. as this limit depens on card having lowest amount of vram.
use 560 for monitor onl or get 2nd titan =) these are probably yhe best options,
depending on wheather You want or not to spend extra money =)
cheers
cheers
