OctaneRender™ Standalone 1.16
roeland
Hi all,
This release fixes the subsurface scattering in diffuse materials.
Changes since 1.15
  • Diffuse transmissive materials with a medium inside are rendered correctly with alpha shadows enabled.
  • Fixed display error with long node names in the node graph editor.
  • Fixed addition of render devices while being paused.
Download:
Windows
ZIP archives:
- 64-bit32-bit
MacOS X
DMG image:
- 32-bit and 64-bit
Linux
ZIP archive:
- 64-bit
Happy rendering,
Your OTOY NZ Team
visuall
Thanks!!!!!
Pictures background , it works now with the depth of field?
OCTANE STANDALONE 4 | Octane For C4D | Win7/64 | 2XGEFORCE GTX1060| I7 3770 | 32GB
Magog
Tnx!!!!!
i7 970 3.3 GHz | 12Gb Ram | GTx550Ti for display + Gainward GTX580 1.5 Gb and Zotac 590 3 Gb for Octane | Win7 x64 __ Softimage 2011.5
morphious2013
I use the Poser Plugin. I have Standalone 1.10. Do I need to update to 1.16 for better renders? Thanks.
ROUBAL
Thanks!!!!!
Hi, I see no reason for that, as anyway the background is only a template and is not intended to be rendered.
You can blur it in your editing software at compositing time if required.
rik25
Thanks ! ;)
Tugpsx
ROUBAL
Great ! I like the new behaviour of nodes names when copying/pasting. Much more logic.
arh-osa
Thanks!
There is an issue with Gradient Texture. Moving control points in gradient strip doesn't affect render.
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
visuall
ROUBAL wrote:
Thanks!!!!!
Salut Roubal, je me permet de te répondre en français.
Pour de la production, d'image d'archi interieur, ext, impossible de rendre comme je le fais quand je teste deux images, http://render.otoy.com/forum/viewtopic.php?f=6&t=32691 soit une illum HDR pour l’arrière plan ( fenêtre) qui lui réagis avec le dof et une image avec le soleil/ciel.. une question de temps... Sur arion par exemple, tu choisi ton background indépendamment de ta source lumineuse, ( Jpg , Png, HDR etc) ou en mode sherical ou plane ( backplate) et ça fonctionne parfaitement.
Hélas Arion ne possède plus ( fryrender à l'époque) tout ce qui est Glare, Blur, Bloom) d'ou Octane.
Tout dépend de l'utilisation en effet, mais j'ai besoin de pouvoir rendre les arrières plans. Une fonction background qui ne sert a rien, tu ne la mets pas en prod.. enfin moi ce que j'en dis hein ;)
Octane étant un des meilleurs render que j'ai essayé (adopté) face à un vray rt2.0 , arion, et autres. manque une ou deux choses BASIC pour que se soit le top du top!
