OctaneRender™ Standalone 1.15
abstrax
Hi all,
This is another bug fix release, which is hopefully the last one before we reach stable 1.20.
Changes since 1.14
  • Fixed missing tooltips for render priority and pane selection
  • Cleaned up render toolbar
  • Removed clutter in node inspector / outliner: Only the names of external nodes are displayed
  • Fixed alignment in edit fields of node inspector
  • Fixed broken background image with non-ASCII characters in path
  • Fixed incorrect alpha transparency when diffuse and transmission are zero
  • Improved noise reduction of diffuse materials with transmission
  • Fixed kernel failure when you try to render a very small image with PMC
  • Fixed memory leak in node graph editor
  • Matte material is now only applied on the first bounce, i.e. the indirect effects of the matte object stay the same
  • Added command line option -R to relink multiple mesh nodes (usage: -R "<mesh node name>=<mesh file path>")
  • Improved bump/normal mapping for diffuse and glossy materials
Download:
Windows
ZIP archives:
- 64-bit32-bit
MacOS X
DMG image:
- 32-bit and 64-bit
Linux
tar.gz archive:
- 64-bit
Happy rendering,
Your OTOY NZ Team
Synthercat
You got a small mistake on that post there abstrax
Check the link of 32bit windows... it links to 1.14 and not 1.15, I copy pasted the link changed the url to download the correct version.
Thank you OctaneRender team for the updates! Can't wait for the blender intergrated!
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
Synthercat
Just one small comment about the new improved bump : OHHHHHHH MYYYYYYYYYY GOOOOOOOOOOOOD!!!! :shock:
I love you guys!!! Thaaaaaaaaaaaaaaaaaaaaaaaaaaaaaank you!
Hey fellow Octaners check this default bump turbulence (scale 50) :
New bump!
New bump!
Old bump
Old bump
Chris
Definitively looking better now :D Thanks Otoy team!
Chris
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
tglaja
Finally the bump looks great.
GTX 560 2GB, AMD FX 8350, 8GB RAM, Win7 x64
Jaberwocky
Thanks Team
That Bump mapping is looking really good now :shock:
Force44
thanks!
http://www.picfad.com
Core i7 2600k @4.2 Ghz | Asus Maxiumus V Extream | 3 x GTX 590 watercooled| Crucial Ballistic Sport 32gb | Crucial m4 64gb | Seasonic Gold 1250 | Octane render| Skethcup Pro 2013 | Blender 2.68
abstrax
Synthercat wrote:You got a small mistake on that post there abstrax
Thanks for the heads up. It's fixed now.
pixelrush
Thanks for the fixes guys. Bump looks nice. :)
BTW a reminder for readers:
The GTX 780/3gb(later 6gb?) launches 23rd May -very soon- and the GTX 770/2gb(later 4gb?) on 31st.
Looks like 25% faster and 10% faster than a 680 repectively but with price advantages.
Haswell cpu launch on the 3th June , seems pretty much the same performance really :(
Edit:
-> When you click in a text field to rename, then type your change, unless you 'enter' it reverts to the original. is this intended? windows allows you to click away from the field and it enters itself I think...only wee issue ;)
-> To be consistant the align views pulldown menu icon should have a tiny triangle showing like for clay, pane and subsampling :P
Octane v1.55
kavorka
New bump and normal are awesome!!!
thanks for the update :)
