some wishes
matttrebor
Hi everyone,
playing for the last days with Octane, pretty impressive.
To me it lacks some important features before used in a production.
Unbiased is great, but I think a bit of flexibility, or tweaking, would be great.
-Hide from camera. Sometimes, we don't want to see a panel light behind an object.
-different viewport/render values should be considered, per exemple the Meshsmooth modifier. For the moment, we need to enter the final iteration in the viewport.
-Obviously, render passes. It can be very handy to seperate reflection from refraction sometimes, and mix everything in post.
-Some procedural maps, like a gradient ramp. It's a great tool fox mixing textures.
-mixing map with fusion mode (additive, multiply...), and the same feature for material.
-real disc and sphere lights (not lowpoly)
-a real aperture system. I thnk the fstop just controls the exposure for the moment, not the blur.
-Going beyond 1 for normal power.
And sorry if these features has already been posted...
matttrebor
And rpf files don't seems to contain any camera data.
gueoct
Wow, that´s a wishlist; i´ve been dreaming of litterally EVERYTHING in this list !!!!!!!!!!
+1
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
Olitech
I second gradient ramp, and would also add noise map. =)
WORKSTATION = Win7x64 / Intel Core i7-5930K [email protected] / 32GB ram / Liquid Cooled 4xTitanX /3dsMax 2014 / Octane Max Plug v2.16a / FARM = Intel i7-2600k 3.70GHz (x2 TitanZ) x 14
matttrebor
The LiveDB's textures path seems to be reset to its default path each time 3dsmax is loaded.
EDIT : is there a way to use bump AND normal ? Normal seems to desactive bump map.
matttrebor
"mix texture" doesn't work for normal map.
matttrebor
It would be nice to have a different roughness value for reflection and refraction.
Some liquids have blurry refraction with a sharp reflection (like all liquids)
It could also be achieve with a mix material with the (missing) additive mode.
matttrebor
This is what I get when AlphaChannel is checked.
Alpha is cropped on the cylinder.
It happens with a diffuse/emitter object.
PAQUITO
Attach light to a camera (inside of the standalone, of course)
It would be very nice to have a checkbox in the camera to turn on/off some kind of flashlight/torch (along with controls for its temperature, power, etc...) That would simplify very much the process of lightning the scene as in the real world.
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
Return to “Autodesk 3Ds Max”
