Skin glossiness
mitzzy50
I hope I can explain my problem clearly. I want to increase the ''shiny'' of the skin of my V4. She is using a ''normal'' skin, the most standard, if that makes sense. I tried increasing the specular in the material tab in Poser. I tried changing the specular and roughness in the material tab in the plug-in. I don't know what else I can do. Perhaps someone can help me. Thank you in advance
KleanZlate
What settings did you try for the roughness node?
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
mitzzy50
The maximum it allows in the plugin. 1.0 I think?
badmilk69
My settings for V4 (well oiled edition) are:
Material: Glossy
Specular: 0.3
Roughness: 0.1 - 0.3
Index: 1.3
i7 2600, 16 GB RAM, 2x Evga 670 SC 4gb, dual boot win7/osxML, 2 SSDs, 3 HDs.
Witpapier
I found that changing skin from Glossy to specular give increases the effect, decreasing the roughnes and increasing the specular values will make your character look shiney like oil.
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
KleanZlate
mitzzy50 wrote:The maximum it allows in the plugin. 1.0 I think?
Roughness decreases or widens the specularity with higher numbers. Try Witpapiers settings. You could even go lower like 0.05 or even lower. If the there is a specular image map controlling the specularity you might try replacing it with a floattexture node. Also test the filmwidth setting. if it's at 1 try a little lower setting.
As everyone else said - get more glossiness/shininess by reducing the roughness.
mitzzy50
Oh wow, thank you so much, I thought I had to increase the roughness... Its the other way, decreasing it increase the ''shine''
mitzzy50
I forgot... I just wanted to say that I'm really grateful with this community. You're all so helpful and quick :) Thank you all
Return to “Poser”
