Archicad 17
rappet
Archicad 17 is released!
http://www.graphisoft.com/archicad/arch ... /overview/
@Paul
Will the plugin work with 17?
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Thanks Jeroen
I will need to re-compile it under the AC17 API. Let me look into this in the next day or so.
EDIT: Have you been able to download it yet Jeroen? https://www.myarchicad.com/PROFILE/ is only giving me AC16 as a download option, not 17.
EDIT2: There are no AC17 API's available yet. Once they become available I'll compile the Octane plugin against them.
rappet
Hi Paul,
No I don't have AC 17 yet.
From what I have seen quickly in the overview the update is not really exciting for me,
Except for probably being much faster with large models.
So I am not in a hurry.
I'll wait for my distributor to send it to me.
Greetings, Jeroen
I now have the AC17 API's (but not an AC17 installer yet). If anyone would like an AC17 build of the plugin to test, pls post on this thread.
Garquitectos
Hi Paul i'm testing now Archicad 17 if you compile the plugin let me know...
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
I am 1/2 way through migrating the plugin to AC17. Should hopefully be ready in the next 24hrs.
Garquitectos
You are a machine!!!
I have the Setup dialog and Viewport working in AC17. However the photorenderer will not compile. Even the AC17 API samples provided by Graphisoft will not compile. I have left a msg on the Graphisoft support forums. Once this is resolved I will be able to provide an AC17 build.
The following link is a build of the plugin for ArchiCAD 17. I had to make some quite major changes, so there are potentially some issues that may arise, so as always, pls don't use this build an critical production work until it's had more testing.
http://render.otoy.com/customerdownload ... 20beta.exe
Garquitectos
For now it works well... now I start with proxies
