Night render ! tips for rendering at night ? (update 10-5)
- visuall
- Contact:
Who would have a night sky in HDRI format ? and tips for rendering at night?
In advance thank you AO3, DL, Diffuse 4 , 45 min in ???? (halzeimer is back) passes..
Cedric
Ps: do not rely on environment textures, it is just set speed for the test. no adjustments.
OCTANE STANDALONE 4 | Octane For C4D | Win7/64 | 2XGEFORCE GTX1060| I7 3770 | 32GB
vertical lines! =p /make them parael adjusting camera position or..
offsetting target (You can find this in camera settings, if I rem good =p
other idea: well, I'd probably go for blue & yellow coloring,
'cos that's what You end up with if the night is not completelly blacked out
check this for inspiration - http://pinterest.com/glimps/blue-yellow/
cheers
cheers
That is a very good comment, I take note for my own workI'd probably go for blue & yellow coloring,
Z77 - i7 2600K - 16Gb | iGPU HD3000 | GTX580 + GTX590
Win7 HP 64 | Sketchup 8 - Octane standalone v1.16
- visuall
- Contact:
Thank you for suggest!!! i see now!!!!glimpse wrote:vertical lines! =p /make them parael adjusting camera position or..
cheers
- visuall
- Contact:
hi, no this is material water weavy (db octane) on a simple plan.Leonardo wrote:That water is amazing! is it modelled?
