poserpro2014 out 21 may
ch0pper
http://poser.smithmicro.com/poser10-poserpro2014/
Poser Pro 2014 Coming May 21, 2013
Fitting Room to convert your existing clothing and props to fit any figure*
Comic Book Preview Mode for color and B&W cartoon illustration and animation
Pixar Subdivision Surfaces for fast and efficient scene building
Bullet Physics for Soft Body Dynamics, Rigid Body and Hair
Morph Brush now supports Sag, Tighten and Loosen so clothing works better
Magnets and Deformers with Weight Maps for the ultimate precision
*Poser Pro 2014 Feature
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
KleanZlate
Poser will have an option of having SubD applied as a render option. That means you can pose figures without subdivision but render them subdivided. Do you guys think that could be implemented in the plugin? It's a great resource saver.
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
ch0pper
i sure it will but i would ask face_off he will know best
I am 99% sure that it work the same way that Genesis does - where there will be a SubD mesh available. I'm half way through making some other changes to the plugin, so once that's done I'll be able to experiment some more. So rendering of subd meshes from Poser10/2014 should be supported by the plugin.
ch0pper
I just Wanna say thank you for all your hard work, it was certainly worth buying the plug-in
just for your feedback and your hard work in the developing this plug-in to poser.
And just about everything I've asked for you have tried to implement into the plug-in.
I'm sure I'm not the only one on this forum who appreciate your hard work
thanks
KleanZlate
ch0pper wrote:face_off
thanks
+1
Paul is one of the people that makes the Poser community so great. Really, great job!
wimvdb
Yes, Paul does an incredible job!
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Witpapier
Id say you qualify to be part of the Avengers Face off... Could just Imagine asking Hulk to create a Node structure.... Thats where you come in handy... and we all need a Hero... which you already are. :)
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
My understanding at this point is that the subd mesh info will NOT be available to addons like the OctaneRender plugin via PoserPython when Poser10 is released next week. So the plugin will render the base mesh, not the subd'd mesh. You can still use Snarly's subdivider script to subd meshes for the plugin if needed. I expect there will be a Poser service release at some point which will expose the subd mesh to PoserPython, and the plugin will then render the subd mesh rather than the base mesh.
Similarly, softbody deformed meshes may render in the plugin in their undeformed state (I haven't tested this yet), since PoserPython has not been updated to provide these deformed vertex positions. But again, this will hopefully only be a short-term situation, rectified by a service release at some point.
Hope that makes sense....
mlru
face_off wrote:My understanding at this point is that the subd mesh info will NOT be available to addons like the OctaneRender plugin via PoserPython when Poser10 is released next week. So the plugin will render the base mesh, not the subd'd mesh.
Oh, bummer!
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
Return to “Poser”
