Octane exporter for C4D version 0.09
abstrax
Hi all,
As promised here comes version 0.09. It has been a while since the last version, because I didn't have much time to work on the exporter plugin. The main changes are a new GUI layout with a fancy banner and a close button (hi Mac users ;) ). I have also added a new command plugin that allows you to export the scene and launch the Octane renderer without opening the export dialog.
For Macs I have changed the way Octane is launched - now it should detect the opened Octane application more reliably. Now animation rendering should also happen in the background, if you are using a Mac. (I don't know how to keep Octane from grabbing the focus on Windows.)
Internally I did some major restructuring - I hope I didn't break anything. Please let me know, if I introduced any bugs or problems.
EDIT: Unfortunately project names with strings are not cleaned up correctly anymore. I just found out and will fix this tonight and release a small bugfix update. Until then please don't use spaces in project names.
These are the PC builds of the plugin:
CINEMA 4D R9.6 (32/64bit):
OctaneExport_0.09_win_r9.6_release.zip
(187.88 KiB) Downloaded 426 times
CINEMA 4D R10.1 - 11.0 (32/64bit):
OctaneExport_0.09_win_r10.1_release.zip
(188.79 KiB) Downloaded 414 times
CINEMA 4D R11.5 (32/64bit):
OctaneExport_0.09_win_r11.5_release.zip
(266.45 KiB) Downloaded 490 times
These are the Mac builds of the plugin:
CINEMA 4D R9.6 (32bit):
OctaneExport_0.09_mac_r9.6_release.zip
(125.61 KiB) Downloaded 381 times
CINEMA 4D R10.1 - 10.5 (32bit):
OctaneExport_0.09_mac_r10.1_release.zip
(163.81 KiB) Downloaded 414 times
CINEMA 4D R11.0 (32/64bit):
OctaneExport_0.09_mac_r11.0_release.zip
(333.55 KiB) Downloaded 401 times
OctaneExport_0.09_mac_r11.5_release.zip
(361.84 KiB) Downloaded 450 times
Happy rendering,
Marcus
pdavid
thank you for good work
windows 7 64|Gigabyte X79-UD3 | Intel Core i7 3930K| (2) GTX TITAN|(1)GTX 670|psu 1200 watt|16gig ram|
Perdition
Thanks! 8-)
Intel i7 5960X | 32Gb DDR4 | GTX 980 Ti 6Gb | Windows 10 64bit
acc24ex
That's a great looking exporter.
How do we set the material in c4d so it has texture emission turned on in octane?
abstrax
acc24ex wrote:That's a great looking exporter.
I don't know yet how those new things will be integrated into the export workflow. -> For now you have to create a material for emitter objects and then modify the material in Octane to make it emit light.
Marcus
hashmi74
Can someone explain how I can retain my existing lightning from C4D? as well as existing materials or do these have to be recreated in Octane?
I'm using C4D 11.008 on a mac.
thanks
p.s. I've taken a look at the Maya exporter video and there is no indication of this other than the use of daylight.
clement
thx Marcus ! :)
Win7 x64 / Cinema4D R15.064 / I7 4930K - Nvidia gtx770
sylvain
Thank you, great job :)
atome451
Thanks a lot Abstrax.
Very good job.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
dadou351
Hello,
It's a great work for this exporter thanks :)
I'm a little pb : when i want export and render my project, the textures are not in Octane Render. Do you know why it don't work ? Have you got a solution about this ?
Thanks again for this job ^^
David
