The problem is explicitly shown on the attached screenshot (sinwave-circular.jpg). I try to enable circular sine wave pattern. It seems that the center of the pattern is far away from the object center (or texture center?). I checked whether this issue is due to the exporter - 3ds max and sketchup - I get the same results.
The problem is gone when the exported object is centered at origin (0,0,0).
Is it something I am doing wrong, or this is a bug?
And another question (sinwave-circular2.jpg) - when setting circular sine wave size the size of central circle in a pattern is large, much larger than outer circles. Can it be fixed to get small center circle?
texture coordinates problem, circular sine wave
