Light Color
bpzen
Hi all
I am trying to get a red glow from a light, candels, i set up a point light in poser, ran the script to create the emmiter and picked a red color for the diffuse color but the light seems white still
Is there any documents / posts for how to get these colors to work?
Also, I set the opacity to 0 because the emitter was showing - is this teh right thing to do to not show the sphere that is the emitter?
PS - on a side note after a day and half using Octane + plug in its the best $$ i have spent on this hobby. I wish I got it sooner. I waited for reality / poser to be out, this blows that away.
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
UnCommonGrafx
Use a texture emitter instead of the blackbody emission model. With it you can color the light.
i7-4770K, 32gb ram, windows 8.1, GTX Titan and gt 620 for display
bpzen
arnt the lights that the script creates form the poser set texture emitters?
KleanZlate
Try setting the emitter to blackbody and lower the temperature value. The default value is 6500 but you could try between 3000 and 4000.
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
If you use the Crate Emitters from Lights script, it will create emitter planes for each light in the scene. In the plugin, Materials tab, select an emitter - you can change the emission color by changing the "emission"->"efficiency or texture" color.
Return to “Poser”
