Animation with octane plugin for C4D?
buzby
Aoktar,
Sorry if this has been covered but is there live animation in C4D in the Octane render window? I saw it in worked in the plugin for Max but not for C4D.
Asrock z77 extreme9 | Intel i7 3770K 3.5 | Win 7 64 bit | (1) EVGA Titan| 30" Apple Cinema Display | LEPA G1600W PSU | 16GB Ram | Storm Trooper Case |
Autodesk Inventor>3DS Max >Cinema 4D R14 Broadcast
buzby wrote:Aoktar,
Are you meaning real time geometry updates? Any update on camera/lights/env./materials naturally changes on live view, also while playing. Geometry updates has some problem with sync objects. Only polygon meshes works nicely
buzby
aoktar wrote:
buzby wrote:Aoktar,
I meant like this
yes if you try you can see, but has sync problems some type objects. Each program has different concept. Main problem to idendificate objects, i'm going to bring a new method
Edit: Finally i have changed system completely with most stabile updater
[vimeo]http://www.vimeo.com/65694139[/vimeo]
