Loading materials?
Elvissuperstar007
Hi I decided to move the entire library archshaders v1 v2
http://www.youtube.com/watch?v=GmC4pxOyJoo
but there is a problem
I want to move the entire library
Nostromo
Ok, I'll have to check what went on with that. Two things tho
1- When you upload to the OctaneLive DB, you will make it available to everyone. Make sure that you don't upload copyrighted material
2- When you save macros (in the OctaneLiveDB or on the filesystem), pictures are embedded inside the macro. This is to make transportable and so that other use can access the material you uploaded without needing to access the image file
If you want to have macros to use only for you, save them in ocm on your filesystem. In the final release, we'll add a 'local DB' tab allowing you to create material macros for your single personal usage.
Regards
/M
