pre2.3 - problem with the passage of light through the glass
Elvissuperstar007
1.23 problem with the passage of light through the glass
Nostromo
can you please post a zip we can use to troubleshoot the issue ?
That would help a lot
Regarding your comment with respect to the left pane earlier on, you can always make it really small, the setting for the UI are stored in the ocs, so it'll be restored everytime you load them
Regards,
/M
Elvissuperstar007
I'll create a video! ok )
Nostromo
We'd rather have a zip file with the exact scene that you are using rather than you publishing a video. That way we can try it here and debug what's going wrong.
Thanks.
imensah
The emissions zip I posted has 2 glass objects(covering an opening in the ceiling and a window on the left ) light never passes through ant of them. I was expecting the daylighting to pass through both
Win 8 Pro 64 Bit | i7 3770 3.5ghz | 8 Gb Ram | 1 x Titan 1 x GTX 480
Nostromo
good, we have an example then, that is sorted :)
Elvissuperstar007
scene that sent you
scene that sent you
