Next frame exporting in background
krzychuc4d
Just wondering would it be possible to improve c4d-octane plug-in
so we could render animation a bit faster.
Currently plug-in is exporting/saving obj when octane finish rendering frame.
My suggestion is
can you do background export of next frame when octane renders image and/or export whole sequence of .obj files.
That could speed up whole process when I'm rendering at work on 3x machines.
example:
I got four shots to render each shot is 150frames long.
Calculation of one frame is 8min exporting time 30sec
with current version of plugin (live export) it takes
480sec + 30sec per frame
150f + 510s = 21h 15m
and background export
480 sec/frame
150f x 480s = 20h
1h15min it's a lot for me
Another useful option to add button "generate script " to render without using C4D.
so I could run octane without locking cinema.
similar to houdini2octane
http://vimeo.com/13902843
would be great if that's possible to add in future release of plug.
thanks
Krzysztof
http://www.3structures.com
https://www.facebook.com/3structures
Ryzen 7 2700X / 32GB RAM / RTX 4070 @Win10 64Bit
Carl S.
This would be great for any program, I was thinking the exact same thing the other day.
abstrax
krzychuc4d wrote:Hi,
My suggestion is
example:
480 sec/frame
150f x 480s = 20h
thanks
Krzysztof
Hi Krzysztoff,
the Octane exporter for C4D 0.08 should do this already?!? I.e. during animation rendering, the plugin starts the export of the next scene 4 seconds (if I remember it correctly) after the launch of Octane. I will have a look at it, when I'm at home.
Regarding the script: That should be easy on Windows. What is the preferred output on Macs?
I'm currently working on 0.09 which should have a few improvements in the UI. And I guess for Octane 2.3 there will be more changes necessary. But we'll see. I hope to release 0.09 maybe this weekend - depending on how much time I have the coming days.
Marcus
