Please auto scroll through list when dragging materials
Moderator: BK
larsmidnatt
In situations where you have more materials in the list than can be shown on a single screen, dragging materials to replace existing ones can be challenging. When you are dragging materials and reach the top of the list, the list does not automatically scroll up.
For example i want to use a wood material from the live DB and it happens to be at the bottom of the list. I want to drag this up all the way to the top of my octane render materials list to replace a material near the top. I can not because the plugin does not automatically scroll up once you reach the top of the visible list.
There are some workarounds like creating a material copy and that will shoot up higher up the list than the live db materials, or by replacing a single scene surface and then once the material is higher up the list replacing the octane material in mind afterward. But would be good if the materials list started scrolling once your mouse was at the upper limit of the visible list.
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
t_3
larsmidnatt wrote:In situations where you have more materials in the list than can be shown on a single screen, dragging materials to replace existing ones can be challenging. When you are dragging materials and reach the top of the list, the list does not automatically scroll up.
appointed. i thought that the framework would take care of this, but in fact it doesn't. what you may try is to scroll the wheel while hovering more in the middle of the list - it works here, a little chunky, but as a workaround for the time being it may help. i do have a special mouse accelerator installed - don't know if it only works because of that, or in general, but you will find out ;) but drag-scroll should happen in any case...
Return to “DAZ Studio”
