need help: got maximum num hdr rgb textures
rappet
Can someone help me please whiel I am working to a deadline right now:
I got maximum num hdr rgb textures; 4/4
but I dont'know how to locate those 4 that are used to solve the problem,
because I want to load a hdr for the environment, but now I cannot.
I am working with a 3dmodel I did not make myself, so I don't know if certain hdr images are used for materials,
or that I used material from DB with hdr rgb textures?
thanx in advance for reply.
greetings,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
I have not yet seen any HDR images in the LiveDB. I also haven't seen HDR images in any of the ArchiCAD libraries. 1 of the 4 will most likely be the environment texturemap. Is it possible you've got 2 copied of Octane running at once? Or Standalone and the AC plugin running at the same time?
rappet
Thanx Paul,
None of the four is environment texturemap,
but you set me on the right track.. I went looking for non-standard used materials in the file.
I did not have a good overview while the original file started out as a Archicad archive file (pla).
I have found two tif-files used for texture.
That will do it for now, because now I can use the environment texturemap I needed to,
but I will find the other two after first making my deadline.
greetz,
Return to “Works In Progress”
