- The sky color in new daylight system can be customized.
- Glare and bloom from the sun retain correct brightness while rendering more samples per pixel.
- Loading lots of very small meshes is more efficient.
- Autofocus works after modifying the rendered geometry.
- Environment light sampling works when disabling alpha shadows.
- Using min_display_samples and subsampling with PMC works correctly.
Limitations on old cards
The PMC kernel and the matte material options don't work on old graphics cards (GTX 2xx, compute model < 2.0).
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to download one archive for your 3ds max® version from the following download links:
3ds max® 2010: http://www.refractivesoftware.com/plugi ... _v1.12.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... _v1.12.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... _v1.12.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... _v1.12.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
