modo > Octane / Export Script v1.05
stenson
Features and Bug Fixes:
-New function to extract the camera target from the modo camera, will make navigation in octane better. (uses the focal length from the modo camera)
-Uses less memory
-Walkthrough Mode, uses 90% less memory while rendering animation, ONLY FOR USE WHEN ONLY THE CAMERA IS ANIMATED
Enjoy
modo2octane_1.022_v1.05.zip
(202 KiB) Downloaded 1263 times
Fredrik Stenson
http://www.stenson.tv
modo resource @
http://www.modo.stenson.tv
sjogren
something mysterious happens when i try to push the browse buttons?
/Sjogren
Windows 10 (64-bit) | GeForce GTX 1070 & 970 (416.34) | i7 6850K | 32 GB System Memory
Modo 12.1v2 | Plugin Version: latest beta 4
teknofreek
@sjogren,
I had the previous version of modo - octane 1.04 installed and therefore had established paths to oct.exe etc.. I could not duplicate this fault. I also removed the path to the binary and tried to browse, was not probs.. it found where octane.exe was and loaded the path.
I have had issues in "c:\..Users.." when I didn't set very specific permissions to allow access to write and read for the opsys. Maybe check those? I'm using Win7 HPrem 64bit.
@Frederik,
tried with two procedural models, and one heavily textured model (naturally exports only rgb shaded in Oct) works a treat!! The exported file is fine in Octane whilst modo is up and loading the generated ocs file into octane "standalone" works fine!
:D
Win 10 Pro 64bit, AMD 1950X 3.6 Ghz, Gigabyte AorusG7 X399 MB, 1x GTX 680 1x GTX 770 mainboard, 4x GTX660ti external, 32 GB onboard mem
Nvidia drivers 388.59
stenson
When you get an error, alway go to the event log and give me the details. The event log can be found:
System > Advanced > Event Log
@sjogren
But, i think i can guess what the problem is. Make sure you've replaced the config (fs_OctaneExporter_GUI.CFG) with the new file. I've add a new variable to this file and i think that's what causing your error. EDIT: Also after you've installed the update, make sure to reboot modo. Or import the new config. (file > import config)
Also make sure that you're having this folder [fs_modoModules] in you scripts folder.
Cheers and thanks guys!
Fredrik Stenson
modo resource @
sjogren
Sorry, my bad.
Its working now.
I deleted a folder from v1.04 (_modules) that I probably needed?
But is this a problem if someone is going to try the script for the first time with v1.05, just some thoughts?
/Sjogren
stenson
sjogren wrote:Sorry, my bad.
Its working now.
/Sjogren
a shit, just saw that i was referring to my old module package in at one line. sorry, it's fixed now though, so if you download again you want have any problems.
thanks for letting me know!
cheers
Fredrik Stenson
modo resource @
flamingox
problem with export animation for octne render, i when export animation to octane, exporter duplicate full scene to freeze_temp_scene and i when complete animation modo write out of memory because duplicate scene for every frame, please help me
sory for my english
stenson
flamingox wrote:problem with export animation for octne render, i when export animation to octane, exporter duplicate full scene to freeze_temp_scene and i when complete animation modo write out of memory because duplicate scene for every frame, please help me
sory for my english
the temp scene is created only at the first rendered frame, your memory issue is due to a modo bug, where modo can't dump the memory during script execution.
how much are you animating, only the camera? if the camera or light is the only thing animated, then activate the 'walkthrough mode' found in the misc tab and modo will use less memory. (check the how_to_use.pdf for issues like this)
let me know how it works out for you!
Fredrik Stenson
modo resource @
flamingox
hi i need export full scene, i have animation assembly rack and i need full scene geometry, no camera or light. But export overflow full memory, i try set virtual memory on 30 GB, but dont effect, I try modo 401 sp4 and sp5 but no effect. I need solve this problem. Thx
zenonn
Hi Stenson I having trouble using the script in modo 302. I get a Script execution error: Error evaluating script import error, line 5; no module named os.
Any ideas?
Return to “Foundry Modo”
