FEATURE REQUEST: save progress of render in a file 4 later
rodrigotrovao
COULD you PUT this MODOS feature in OCTANE??
Progressive refinement rendering enhancements
http://www.youtube.com/watch?feature=pl ... uzsStWIOOA
feature: save the progress of rendering in a file so you could start later?
glimpse
agree, thatcould be really interesting fewturea!
but for now, the workaround would be like this:
if You render let's say to some amount of samples/pix & save out the resulting image, but it's too noisy..
simply restart rendition later..render the same amount & stack two in PS =)
on the progressive refinement, simply crank the samples up to 64k & let it cook, .. save somewhere in the progress, but leave the render cookin'..
cheers
oudou
Hi, today i was thinking about another feature that would be nice :
in animation when using autofocus, focus can change radically from one frame to another, a feature for applying a "speed of focus adaptation" should be nice. Or may be i don't found it if it already exist ??
Indeed, i could use target focal point animation to simulate it, but sometime i love being lazy :)
Too, i don't know how to use skylight, and having a background that "do nothing" for lighting for exemple clouds, background plates (some times i just put them very far/very huge so they havent too much influence)... just using photoshop for that, but alpha with foliage aren't always an easy task with some very contrasted backgounds.
Return to “Autodesk 3Ds Max”
