OctaneRender® for Maya® v1.11a beta [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • New 1.11 engine. This new release is made to test the new SDK for autorisation problems which some users had in releases using previous SDK... Not all features of new engine are enabled in this release, they will be added in next versions.
  • Added "extra controls" section to all Octane nodes.
  • Kernel settings now are refreshed in "Camera animation" too. So, the animated "Max. samples override" in camera settings will work.
  • Changed the default value of "Scene scale factor": now it does not calculate automatically from current Maya units to meters, but just is set to 1.0 always.
  • A few minor fixes...
DOWNLOAD
OctaneRender for Maya v1.11a beta (35.3MB autoinstaller file)
Yours,
The OctaneRender™ Team.
ypolyz
Thank you JimStar!
renmaxhb
The "U" butten cannot work nice yet,my project' Scences canonot render.
why cannot export nice like 2.59q or before?
renmaxhb wrote:Thanks,
Can you please give me some scene on which it does not work? As soon as I will be able to reproduce it - it will be fixed.;)
renmaxhb
This is .
And My maya scences have many refrerence files,some objects can not rename,I hope the plugin allow the same name objects.
Desktop.zip
(841.19 KiB) Downloaded 313 times
renmaxhb
I tested 2.58q,it can render any maya scence!!
renmaxhb wrote:I tested 2.58q,it can render any maya scence!!
Yes, it can. And this was the bug which was fixed in next versions. As due to this behaviour, where the plugin did not have the unique key for each rendered object - a lot of weird issues were popped up in some cases...
Yes, with references it may be the problem with renaming...
Thanks for the report, I will think how it may be solved...
renmaxhb
Thanks a lot. :D
TBFX
renmaxhb wrote:And My maya scences have many refrerence files,some objects can not rename,
Try going back and running the unique name script on the files you are referencing and re-saving them. If you have nested references you will need to start at the bottom of the reference tree and work your way up.
T.
Return to “Autodesk Maya”
