Octane suddenly doesn't launch?
[email protected]
Hi, I'm using Octane 1.11a, but my problem appeared also on 1.10 version, so all was ok, and I wanted to render some animation out, all was rendering fine, than I changed some material, I fire up render again and it says Processing geometry, than Rendering... and all is black... nothing is rendering,
when I try to open octane render viewport, it doesn't respond... he opens but he doesn't load the scene, so no render field in it,
now I wanted to take print screen with black max buffer render window and octane render viewport... but now everything is freezing...
tried restart, but nothing...
any ideas what is going on?
I got some nvidia physics error a few minutes ago
Windows 10 64bit, Intel i5, 32gb Ram, 2x nvidia 1080ti, Driver: 390.77
[email protected]
oh and just to say, I treied opening a new max scene and load octane there, but problem is the same
Nat
I ve got the same problem with octane for poser since yesterday.
I have tro try 2 or three times, sometimes I have to close Poser.
suvakas
Try powering off the system and then restarting.
Has helped me a few times.
Suv
[email protected]
ok now I realized that all my accounts are Disabled for some reason..., now I activated all and all is ok
you can close this topic! :)
Hi Nat
If you get a blank Viewport but no cuda error - try clicking the Reset button in the Cuda Devices tab - that should kick things off.
Nat
Thank you for the advice, I ll try this next time.
Return to “Autodesk 3Ds Max”
