will Octane ever have time line so lighting and/or materials can be
animated?
Possible to animate light sources in Octane?
2 GPUs: Zotac GTX 580 1.5gb Amp! GPU for Octane....Galaxy 210 1gb for display
CPU: AMD Phenom II X4 955,3.2 ghz RAM: 8gb OS: Win7 64
- Elvissuperstar007
- Contact:
http://www.octanepowertools.com/
Octane Power Tools
Features
Octane Power Tools is a powerful software that let you reduce time and effort while rendering animation and stills in Octane Render. Octane Power Tools main features for the current version are:
Import camera animation data files exported from supported 3D Packages .
Animate camera in Octane Render.
Animate Light in Octane Render and define light animation start and end frame.
Set render time for each frame in milliSeconds, Seconds, Minutes or Hours.
Set Start and End frame of camera animation, i.e. animate segment of the imported camera animation.
Set Render to Every Nth Frame.
Realtime animation in Octane Render viewport for test before production.
Render several cameras each with its own settings in a batch process.
Option to Animate Sun Light with each camera animation.
Save output frames with Camera Name Prefix.
Progress Window of current rendered frame, remaining frame rendering time and remaining animation rendering time.
Option to Hide Octane Power Tools and Octane Render while rendering so the user is able to use their PC.
Save Light positions in Octane Render.
Save Camera positions in Octane Render.
Combine saved Light/Camera position.
Octane Power Tools
Features
All the plugins support animation of this type into Octane too.
Octane Power Tools...I tried the demo ... it looks very cool, and may get it.
Do you know if JimStar's new plugin be similar? Better? As fast?
Not sure if I should get OPTs or wait for JimStar's plugin.
I was hoping maybe Otoy will add a timeline with keyframes to Octane in
the (not too distant) future so we can at least animate Octane materials
and the Octane sun.
and the Octane sun.
- p3taoctane
RIght now (unless I am mistaken) Jimstar can clarify this.
You can animate the mesh itself that has light emission octane attributes (so you can resize it to zero or move it behind something etc... i.e. alter the effect of the scene as to how it is lit over time... but you can not key frame the intensity of the light settings or change its color etc.
Camera motion and all mesh objects are animatable as you can within Maya... you can change a Maya shader color over time... you can not change a octane shade diffuse color over time etc.
Can you do that in Poser Paul?
Poser takes the ambient power ("Ambient_Value") of the Poser emitter geometry material and uses it as the blackbody or texture emitter power each frame. So you can aminate the mesh position, shape, etc plus the emission power.
yes the maya integrated renderer can animate lights in all the different ways, and it is up and running now.megacal wrote:Octane Power Tools...I tried the demo ... it looks very cool, and may get it.
and the Octane sun.
There a 3 options in the maya octane render globals about how the octane renderer updates, camera only, movable proxies, and all - you will need to select 'all' for your lights attributes to update properly.
regards,
JF.
Ok, I understand now.....JimStar's plugin is the Blender version of those for Maya & Poser.
I thought it was his own plugin (independent of Otoy).
Hope to see it released soon....then one for C4D.
Later.....
just found out that OPTs works with both Blender AND C4D,
(also with Max, Maya, SketchUp, XSI, & Lightwave!).
So for me, it's the best/economical option......61.49 Euros vs 99 Euros each for Blender & C4D plugins.
Thanks Elvis,
дуже дякую! =)
Thanks Elvis,
дуже дякую! =)
