Animation rendering broken??
mbetke
Using 1.03 here and strange my animation rendering is not working properly. :(
I made the parts I want to be moved an "Octane proxy" but one "rolling out" effect is not working. I unchecked also "update geometry".
basically it is like a carpet which unrolls. I did it with an animated gizmo on a bend modifer. It seems this doesn't work in Octane?
Also my camera doesn't move. Whats up here? I think it was possible to have animations withou needing to export all geometry again every frame?
EDIT: I also checked "autoupdate movable proxy".
PURE3D Visualisierungen
Karba
mbetke wrote:Using 1.03 here and strange my animation rendering is not working properly. :(
Can I have your scene?
[email protected]
mbetke
I'm a bit stupid. I had to check update animation geometry.
For some reasons I thought it will result complete export of whole scene. Maybe it was the case in pre-instances times.
After clicking the checkbox my geom updated fast without reexport of whole scene.
Karba
mbetke wrote:I'm a bit stupid. I had to check update animation geometry.
What about camera? Does it work?
mbetke
The image which gets saved has correct camera position.
The image inside the "buffer" is wrong.
Image in octane real time is correct too.
suvakas
What the "update animation geometry" is supposed to do?
If it should only update animated geometry, then it's not working.
Suv
Return to “Autodesk 3Ds Max”
