KeyError:39
gazukull
Out of nowhere... whenever attempt to launch the LiveDB for materials I now get the above error.
I am on 1.02r for the plugin and 1.10 for Octane Standalone. Error occurred before I moved to 1.10 Octane standalone as well. I thought that moving to new version might clear things up.
Another strange thing my Poser drive that it seems to be calling for is on the D: drive instead. (Which is probably the problem)
I have not moved my poser directory nor octane's directory. nothing changed... it just stopped working today after being used earlier in the day.
Any help would be appreciated! I am loving the plugin!
- Operating System: win 7 x 64
- 25GB ram
- 660 ti 2 x 650 ti
- Nvidia driver 306.97
- Poser version 9.0.3.23027
-G
Win 8.1 X64 / 6x780GTX / AMD FX-8320 / 32GB RAM
gazukull
DEBUG:root:addon:__init__
DEBUG:root:Python Version : 2.7
DEBUG:root:Platform : win32
DEBUG:root:OS Architecture : 64bit
DEBUG:root:Poser Version : 9.0
DEBUG:root:Poser App Version : 9.0.3 .23027
DEBUG:root:Plugin Version : 1.02r
DEBUG:root:OctanePlugin.py = D:\POSER\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.pyc
DEBUG:root:OctaneDefaults.py = D:\POSER\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctaneDefaults.pyc
DEBUG:root:Loading Octane library D:\POSER\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\64\PoserOctane64.dll
DEBUG:root:Paths
DEBUG:root:D:\POSER\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\64
DEBUG:root:D:\POSER\Poser Pro 2012\Runtime\Python\PoserScripts
DEBUG:root:D:\POSER\Poser Pro 2012\python27.zip
DEBUG:root:D:\POSER\Poser Pro 2012\Runtime\Python\DLLs
DEBUG:root:D:\POSER\Poser Pro 2012\Runtime\Python\lib
DEBUG:root:D:\POSER\Poser Pro 2012\Runtime\Python\lib\plat-win
DEBUG:root:D:\POSER\Poser Pro 2012\Runtime\Python\lib\lib-tk
DEBUG:root:D:\POSER\Poser Pro 2012\Runtime\Python\lib\site-packages
DEBUG:root:D:\POSER\Poser Pro 2012\Runtime\Python\lib\site-packages\wx-2.9.1-msw
DEBUG:root:octane.dll: date/time = 1356105360.0, filesize = 11016192
DEBUG:root:PoserOctane.dll: date/time = Sat Dec 29 14:29:20 2012, filesize = 283648
DEBUG:root:Current Directory = D:\POSER\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\64
DEBUG:root:Octane library loaded
DEBUG:root:addon:load
DEBUG:root:PoserOctaneStart returned False
DEBUG:root:init:objectsAdded
DEBUG:root:addon:render
DEBUG:root:setup
DEBUG:root:Light 4 set as Sunlight
DEBUG:root:ShowOctaneOptionsWindow
DEBUG:root:PoserOctaneSetAccount() returned True
DEBUG:root:Environment Texturemap = D:\POSER\Poser Pro 2012\Runtime\Textures\LightProbes\OfficeFoyerBG_512.jpg
DEBUG:root:
DEBUG:root:copyMeshToOctane
DEBUG:root:================
DEBUG:root:geometrygroup node created 0xa504290L
DEBUG:root:total number of vertices = 441, vertex indices = 1600, normals = 441, uvs = 442, uv indices = 1600, polygons = 400
DEBUG:root:transferring actor GROUND geometry to octane
DEBUG:root: number of vertices = 441, normals = 441, uvs = 441, polygons = 400, sets = 1600, texture sets = 1600
DEBUG:root: Mesh node for GROUND created 0xa516d10L
DEBUG:root:created geometrycache for prop GROUND pinNum=0
DEBUG:root:stage 2 (fill ctypes arrays) elapsed = 0:00:00.012000
DEBUG:root:Mesh object created
DEBUG:root:creating new texture environment node
DEBUG:root:creating new image node
DEBUG:root:environment node created 0xa516e90L
DEBUG:root:creating new thinlens node
DEBUG:root:camera node created 0xa525b90L
DEBUG:root:creating new int2resolution node
DEBUG:root:savedTreeInfo resolution size set to 800 x600
DEBUG:root:resolution node created 0xa53bb90L
DEBUG:root:creating new camera node
DEBUG:root:imager node created 0xa53bf10L
DEBUG:root:creating new pathtracing node
DEBUG:root:kernel node created 0xa569390L
DEBUG:root:creating new postprocessing node
DEBUG:root:postproc node created 0xa569790L
DEBUG:root:stage 3 elapsed (call PoserOctaneStartTestRender) = 0:00:00.006000
DEBUG:root:Converting material Preview from Poser Material
DEBUG:root:creating new glossy node
DEBUG:root:setting Preview to glossy
DEBUG:root:setting rendertarget node 0xa504590L
DEBUG:root:stage 4 elapsed = 0:00:00.053000
DEBUG:root:Octane License is activated
DEBUG:root:init:objectsRenamed
DEBUG:root:Found MaterialDBCategory 1 1 root -1
DEBUG:root:Found MaterialDBCategory 2 2 Materials 1
DEBUG:root:Found MaterialDBCategory 3 3 Textures 1
DEBUG:root:Found MaterialDBCategory 4 4 Emissions 1
DEBUG:root:Found MaterialDBCategory 5 5 Organic 2
DEBUG:root:Found MaterialDBCategory 9 9 Non-Organic 2
DEBUG:root:Found MaterialDBCategory 8 8 Misc 2
DEBUG:root:Found MaterialDBCategory 12 12 Stone 5
DEBUG:root:Found MaterialDBCategory 11 11 Wood 5
DEBUG:root:Found MaterialDBCategory 13 13 Vegetation 5
DEBUG:root:Found MaterialDBCategory 14 14 Skin 5
DEBUG:root:Found MaterialDBCategory 15 15 Metal 9
DEBUG:root:Found MaterialDBCategory 16 16 Plastic 9
DEBUG:root:Found MaterialDBCategory 17 17 Glass 9
DEBUG:root:Found MaterialDBCategory 18 18 Cloth 9
DEBUG:root:Found MaterialDBCategory 19 19 Paint 9
DEBUG:root:Found MaterialDBCategory 20 20 Checkerboard 9
DEBUG:root:Found MaterialDBCategory 21 21 Liquids 5
DEBUG:root:Found MaterialDBCategory 22 22 Composite 9
DEBUG:root:Found MaterialDBCategory 23 23 Organic 3
DEBUG:root:Found MaterialDBCategory 24 24 Non-Organic 3
DEBUG:root:Found MaterialDBCategory 25 25 Misc 3
DEBUG:root:Found MaterialDBCategory 26 26 Stone 23
DEBUG:root:Found MaterialDBCategory 27 27 Wood 23
DEBUG:root:Found MaterialDBCategory 28 28 Vegetation 23
DEBUG:root:Found MaterialDBCategory 29 29 Skin 23
DEBUG:root:Found MaterialDBCategory 30 30 Metal 24
DEBUG:root:Found MaterialDBCategory 31 31 Plastic 24
DEBUG:root:Found MaterialDBCategory 32 32 Glass 24
DEBUG:root:Found MaterialDBCategory 33 33 Cloth 24
DEBUG:root:Found MaterialDBCategory 34 34 Paint 24
DEBUG:root:Found MaterialDBCategory 35 35 Checkerboard 24
DEBUG:root:Found MaterialDBCategory 36 36 Liquids 23
DEBUG:root:Found MaterialDBCategory 37 37 Composite 24
DEBUG:root:Found MaterialDBCategory 38 38 Lamp Spectra 4
DEBUG:root:Found MaterialDBCategory 40 40 Absolute Textures 39
Hi. Have you tried a reboot of your PC?
EDIT: I wonder if a material has been added to the liveDb which is causing this. I will check tomorrow.
Regarding the LiveDB error - there appears to be a corrupted category that has been added to the LiveDB. I will code a fix so that it ignores this new category and release it in the next 24hrs.
gazukull
Thanks much for the quick response!
- G
I have updated the 1.02r installer to rectify this issue. Pls re-download from the 1.02r installer link in this forum.
Return to “Poser”
