How do I stop render animation in the MAX2Octane 1.022f ?
anikdw
I am using 3ds max 2011 version via plugin MAX2Octane 1.022f.
I usually work to test 90 frame(3sec) animations.
sometimes I need to stop rendering at the 10 frame for example.
but OctaneRender S/W cannot stop at the middle frame on rendering animation, continue to next frame.
If it stoped a frame by force, automatically do rendering next frame.
how can i stop render animation at the middle frame ?
kilaD
Hold escape to stop the animation export/render.
The script checks to see if the last rendered png exist, then continues to render. If not it should stop.
Should this not work, ctrl+alt+del and kill the cmd.exe process - hold esc while pressing yes to delete the process
Hello
Return to “Autodesk 3Ds Max”
