Is there a working Octane to Blender script yet for either V2.49 or 2.5?
I cannot successfully get the scripts (that I have found) to run without errors.
One main reason I chose Octane was because I was under the impression that it would export directly.
I know it's early days.
Have I missed something somewhere along the line.
Mark
Is there a working Octane to Blender script yet?
- greg.thoman
The Script works great. I'm sure that if there was a major issue with it there would be many more complaints.
What errors are you getting? We can't offer assistance if we don't know the problem.
When I first started using it, I thought the same... but it turned out to be a user error.
AMD Phenom II X6 3.2 || 12 GB DDR3
GTX 480 1.5GB X 3 Liquid Cooled
RaidMax 1000W PSU || Corsair 850W PSU
MSI NF890-G65 Mainboard || Windows 7 64 Bit
Hi Greg,
I am new to Blender and Octane. I would like to use them both on the Mac OS side of my MacBook Pro.
Octane runs fine on it. a bit slow that's not a big issue for me.
When I open and run the script is errors out and in the console if highlights the import BPyMesh is highlighted.
Tried different meshes etc. and still the same.
I must be doing something wrong? I put the script in: users/marksnyder/applications/Blender/ Python Scripts.
I have both 2.49 and 2.5.
Does this help at all?
Mark
Mark
- greg.thoman
First, my working knowledge is 2.49. can you manually export from blender to octane? use *.obj in the export menu.
Then maybe try loading the script in the text editor by cutting and pasting from a notepad like application, then run the script from the text menu. (there's a menu option for it) Try exporting that way. Also, it's easiest not to have any spaces in your file paths on the export window.
Let me know if that gets you anywhere.
- greg.thoman
What error is it throwing?
- greg.thoman
have you tried exporting as an obj with the file menu yet with no script? and then loading that mesh in octane?
- enricocerica
- Contact:
Hi there,
Sorry for the delayed reply.
As stated in the related download thread, the export script is not yet available for Mac.
As I don't own a Mac, I couldn't finalise it for that platform, if somebody may have a look to it and provide me with the changes to make to the script, that would be great
http://www.myline.be
- greg.thoman
Well, there you have it
