clouds and terrain
MaTtY631990
A couple of simple scenes done here testing mainly terrain texturing and clouds. Used Photoshop for compositing clouds in. Terrain heightmap made in L3DT and created with dreamscape plugin. 10 minutes for the glass of wine image and about 7 minutes for the landscape image. Rendered with Octane3dsmax v1.02.
gabrielefx
nice!
how you modeled the rocks?
MaTtY631990
I used a program called L3DT which can generates heightmaps as well terrain normals and other maps. Their is a standard edition and professional edition which you can use. Standard is freely available to download and use with resolution limit. The professional edition you have to buy for but can give you crazy texture resolutions to export to.
kavorka
Nice, but I feel like the snow is too soft, needs some edges where is falls, and places where the top turns to ice in the sun. looks a little too blobby.
otherwise, awesome renders :)
MaTtY631990
Thanks :) . will try to some improvements with the snow. I just used the sun/sky system to get better dynamic lighting and shadows, but I suppose this a cost of going for more realism. Might try with either lowering the sun so it's reaching the peaks or with a good HDR.
MaTtY631990
some new renders. Will have a play with creating an ice material.
Zay
Looks good. Just needs some SubD to remove the shadow spikes.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
ROUBAL
Great work on these mountains !
MaTtY631990
Zay wrote:Looks good. Just needs some SubD to remove the shadow spikes.
Will try apply a bit more resolution.
gabrielefx
MaTtY631990 wrote:I used a program called L3DT which can generates heightmaps as well terrain normals and other maps. Their is a standard edition and professional edition which you can use. Standard is freely available to download and use with resolution limit. The professional edition you have to buy for but can give you crazy texture resolutions to export to.
try this
http://www.west-racing.com/mf/?page_id=2979
