Im currently looking at which pieces im gonna put in my next workstation.
I already builded workstations at work but never mutli-gpu ones
I want advice for a workstation with one gtx260 (or gtx275) that can evolve in a triple gtx260 (or gtx275) setup later
So I need a power supply that can take three gtx260 without problems, a motherboard with three pci-e
And enough memory for all the GPUs. For CPU I will use an i7, don't know wich one yet.
For power supply I looked at Enermax ones
REVOLUTION85+ 950W CrossFireX
REVOLUTION85+ 950W SLI
I don't know why there's two different models, because beside the name I didn't find any features difference
I need to find a good motherboard that can run three gtx260 at full speed without SLI
Anyone got a multi-gpu setup and can share wich motherboard he use?
Here's the motherboard I found
Asus intel socket 1336 P6T
It says 3 x PCIe 2.0 x16 (at x16/x16/x4 mode) what x16/x16/x4 mode mean ?
At first I will buy my workstation with only one gtx260 and I will wait for Octane to support multi-gpu
Also does multi-gpu work better inside windows if they all got the same ammount of memory?
For example if you have three gtx260 you should have six 2gb dimm? So each gpu got 4gb memory
I also need to know if with three gtx260 Octane render will not slow down all the windows UI
Or do I need to find a four pci-e motherboard an add a cheap GPU only for windows
(edit: damn im sorry im in the wrong forum, should be on OS, Drivers & Hardware
