cuda error
ch0pper
i getting this error cuba error: mesh prameter ERROR (REF TO CUDA.LOG) FOR DETAILS
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
This is potentially due to irregular geometry in the scene (ie. A poly with only 2 vertices). If you check the octaneplugin.log file you can see which geometry piece caused the issue. The next release will handle irregular geometry in a better way.
ch0pper
thanks for the reply.
i going by KFA2 GeForce GTX 680 EX OC 4096MB GDDR5 PCI-Express Graphics Card
http://www.overclockers.co.uk/showprodu ... ubcat=2255
i take it one these would work quite well?
If the cuda error is due to some non-standard geometry, then a new card is unlikely to help. If you post your octaneplugin.log file here, and I tell you what geometry is causing the issue.
ch0pper
were does octaneplugin.log live?
The Poser temp directory. Pls see http://render.otoy.com/forum/viewtopic.php?f=45&t=26231 for details.
Return to “Poser”
