OctaneRender® for Maya® v1.02a beta [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
This is the "quick-fix" version.
BUG FIXES SINCE LAST RELEASE:
  • Fixed the bug when the wrong materials rendered in particles in some circumstances.
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
ypolyz
JimStar,
many thank you again, all is well now.
arh-osa
Thank you, JimStar!
Sometimes I need to render images without dof. It would be pretty well to make min value of camera aperture equal to 0.0.
I think it is possible since engine has been changed.
So I can set min value using addAttr:
     addAttr -e -min 0.0 ($camShp+".octAperture");
     setAttr ($camShp+".octAperture") 0.0;
But if I won't use scriping it will be impossible to set the value of Aperture less than 0.01 by hand.
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
Andrew88
great new features :)
hm, i was hoping the broken batch render had been fixed now :(
I am still getting the Error: OctaneRender is not activated!
And i just deactivated it and waited for over an hour before activating it again.
i hope it will get fixed soon..
anyway, still love the octane render so far :)
Andrew88 wrote:I am still getting the Error: OctaneRender is not activated!
Is the mayabatch.exe executed on the same machine where the plugin was activated in the Maya itself?
Andrew88
Yes i am rendering from the machine that the plugin has been activated on.
skywxp3d
Hmm, this version and the previous one don't work on my machine at all... it simply wont render anything....
weird! I get no errors either, and nothing comes up in verbose mode, it just doesn't seem to do anything at all when I try and render?
Win 7 64bit with 2 GeForce GTX 260's
Sky Kensok
skywxp3d
skywxp3d wrote:Hmm, this version and the previous one don't work on my machine at all... it simply wont render anything....
OK - so I tried the latest standalone build, and it says it does not support GTX 260's right in the dialog box - so I guess that answers my question.
Will they be supporting these cards anymore or am I out of luck?
Thanks!
Sky
Sky Kensok
Q-Games
Thank you JimStar!
Intel Core i7-2600 CPU @ 3.40GHz | RAM 16GB DDR3 | GeForce GTX 480 Core 405 MHz | Win7 64bit Jap
igi00
I have a question. Does this act like a demo also, or I have to install dedicated "maya v1.0 RC3c beta demo" instead?
Return to “Autodesk Maya”
