580 GTX and 68GTX running together
p3taoctane
I seem to remember something about having trouble getting these two cards running at the same time, but can't find the solution to it.
I just put in a 680 GTX with my 580 GTX and it shows up in the Device manager fin with latest driver but when I launch octane 1.02 I get a blank black screen. File, edit, NOde and Help menu show up and it says it is activated but nothing else and no activity on the menus. If I resize the screen it does not refresh properly. I am running the display off the 580 for now.
Any ideas or topics that solved this would be great
p3taoctane
Does any body have a 680 running with 1.02... if so what drivers are you using. I had to take mine out and leave the 580s alone until I can figure this out.
Stumped
Any help appreciated
abstrax
I'm using a 580 and a 690 together and don't have any problems. Driver is 306.97.
What does the log window say?
Marcus
p3taoctane
sorry marcus I wish i could tell you... right now I can't even get to any screen to help me... I installed a bunch of new drivers and now I cant even get ANYTHING in my screen... even the bios to tell it to boot to instal disk...
Peter
p3taoctane
Gidday Marcus,
I got the 680GTX's up and running by taking everything out and Octane ran fine and rendered great.
As soon as I put another 580 in in any slot I can't even boot into the whole bloody OS
Any ideas...
Peter
p3taoctane
More on this... I added a 690GTX and that did not cause any problems.
Octane running on all 3 cards no problem
As soon as I put in the 580 again...no boot... it is like as soon as a non K card goes in the slots... no os boot.
ANY ideas on that one.
If I manage to get boot up... and both sets of cards running... you mentioned the log... where do I find that.
Peter
portdog77
See if there are any BIOS updates for your motherboard. Also check their website and see if there are any driver updates for your board too.
"Hackintosh" OS X 10.7.5 CPU: intel 990X @4.2GHz RAM: 48GB DDR3 @1633MHz BootDISK: 2x Sandisk SATA3 120GB SSD GPU: 2x GTX 590 + GTX 690 MB: EVGA Classified3 PSU: Rosewill Lighting 1000w Case: Falcon Northwest MachV -Black •.:-:.•
p3taoctane
Thanks I did insatl a bio update and as far as I can see the board is now up to date. Thanks for the idea though
jitendra
I have similar issue.
I am running well with gtx 580 and 590.
As soon as I add gtx 470 its not displayed anywhere in device manager.
If I run gtx 470 alone it works well.
I tried gtx 560ti to run with gtx 580 and 590 but it doesn't work. Device manager shows problem with 560Ti. However, when I use ONLY 560ti.. it works without any issue.
I have rampage III extreme board.
Best Regards, Jitendra
grimm
Sounds like it might be a power issue? Is your power supply able to handle the load of both cards?
Jason
