"Trouble" with the Poser plug-in
fallen21
Hello all,
First of all it's a real pleasure to, finally, find an "easy" realistic render software (i'm talking about the plug-in, standalone version is easier than others soft still "hard" for someone like me :p).
I'm enjoying to make scene in Poser then transfer to Octane (via the plug-in), BUT i'm encountered a problem with the plug-in if my scene is too complex i've an alert who says me i'm out of range of the software/hardware (RGB textures / Grayscale Textures, these two in particular).
I've tried if this alert come from my hardware & so test a similar scene composed in Daz then exported to the standalone version, here no alert.
I really would prefer to use the plug-in (auto-converting) than the standalone, is it a "bug" from the plug-in (or whatever) & it will be resolved ? Or simply integrate an option that let us save the scene made in Poser & then converted to octane in an octane scene :).
Otherwise the plug-in worked, if my scene stay simple :p.
Kind regards.
Hi there. If you open the viewport, put your mouse over the bottom status bar - it will tell you the current texture numbers used verses total available as reported by Octane. Octane Standalone will not give you the warning - it will simply render materials black for the textures that are over the limit.
The warning you are getting is based on the limits set in the OctaneDefaults.py file. If you have a GTX 600 series GTX card - your card can handle more than the limits in the settings file (think 600 series max is 144 RGB, etc). Check the FAQ in this Poser forum for the actual limits.
If you are actually going over your cards limits, if it grayscale textures that are over limit, you can rightclick in the Material tab of the plugin to remove the bump maps from the figure/scene or material. I will be enhancing this function in the next version.
fallen21
Ok! Indeed i'm using a GTX 680 4go, is there a way to "delete" this alert (put the alert on the right limit of my card ^^) ?
Then it's more frequently greyscale textures warning than RGB (when i hit image stat => RGB: 64max / Greyscale: 32max).
Thanks so much to enlighten me about this & for the tips.
If you have a 600 series card, change the following in OctaneDefaults.py (which is in python\addons\OctaneRender for poser)....
MAX_NUMBER_OF_RGBA_TEXTURES = 144 # This is the maximum number of LDR "image" and "alphaimage" textures that your video card can store.
MAX_NUMBER_OF_GRAYSCALE_TEXTURES = 68 # This is the maximum number LDR of "floatimage" textures that your video card can store.
MAX_NUMBER_OF_HDR_RGBA_TEXTURES = 10 # This is the maximum number of HDR "image" and "alphaimage" textures that your video card can store.
MAX_NUMBER_OF_HDR_GRAYSCALE_TEXTURES = 10
In a future version (not the next one!) this will be obtained automatically from your video card. In the meantime, edit the file. Also, when you install future versions of the plugin, remember to update the file, since it will be overwritten by the installer.
fallen21
Great, thank you for your help.
Return to “Poser”
