orthographic/parallel camera
krzychuc4d
Hi there!
is there any way I could export orthographic/parallel camera to octane ?
http://www.3structures.com
https://www.facebook.com/3structures
Ryzen 7 2700X / 32GB RAM / RTX 4070 @Win10 64Bit
steveps3
Yes, download the latest release. It is in there.
(OS) Windows 7(64)
hi, create a rendertarget in octane with the ortographic camera, then add the name of the rendertarget in the exporter and uncheck the export cinema camera in the second tab of the exporter.
that's it ;)
krzychuc4d
but how to export this camera to octane ?
current exporter doesn't support orthographic switch
krzychuc4d
bepeg4d wrote:hi, create a rendertarget in octane with the ortographic camera, then add the name of the rendertarget in the exporter and uncheck the export cinema camera in the second tab of the exporter.
that's it ;)
if I deselect "export camera"
how can I export camera position for animated camera ?
hi, i have made a quick test and it's more easy of what i've expected, simply find a prospective camera similar to the orthographic view that you need, export, check the option in the octane camera and save the ocs and voilà, the orthographic camera stays so it's also possible to animate it ;)
I had only correct the camera shift y value for centering the subject.
abstrax
Currently there is no way to way to export an orthographic camera to Octane. We will add this in the near future.
Marcus
krzychuc4d
abstrax wrote:Currently there is no way to way to export an orthographic camera to Octane. We will add this in the near future.
Marcus
Would it be possible to make future today Octane Team ? :)
seriously I will really need this feature until next week :/
next week will have to start render commercial animation
I think I'm stuck
thanks anyway!
abstrax
Marcus
I think I'm stuck
thanks anyway!
It's quite unlikely that there will be an update in Octane until next year, but I will have a look if I can work around it in the exporter. You would still have to enable the orthographic option in the Octane scene manually, but after that it should export correctly. I will see what I can do.
Marcus
Reason: fixed type: I wanted to say that there probably will be no update until next year
krzychuc4d
That would be great !
if you could find quick way to do that.
I Hope it will not take to much of your time.
Thanks in advance!
