Hi All, I just downloaded the demo version of octane, and i would like to try it with a model that I did in zbrush.
My model has multiple uv tiles with different textures files associated to every tile. Is octane capable of handle multiple textures on model with multiple tiles? If yes how do I make it work? I searched the manual but i can't find any useful information about assigning multiple textures.
PS: For multiple UV tiles i mean this:
http://www.neilblevins.com/cg_education ... _tiles.htm
Does Octane standalone handles multiple UV tiles?
Thanks for the rapid answer Fooze,
I'm new to Octane but as i could undersand, when I import an obj, Octane will use materials to distinguish different objects on which i can apply different Octane materials (is that correct?) .
So I could apply two different materials to my object faces (One per uv tile, if i have two uv tiles) in Maya and export the obj file.
But how do I have to setup the two different tiles? Do i have to make it overlap on the main uv tile to make Octane correctly handle it? I supposed this because as you say, octane "sees" only the first, main tile of the uv space so every tile should be translatet on the first tile..
Another question,
Are there any normal continuity issues with two materials applied on the same mesh?
Another question,
Hi RBancone,
If i'm understanding you correctly then:
1) yes, using different materials (one per UV tile) should work.
2) You should just be able to leave the UV's alone. Textures in octane will display as tiled, so UV's outside 0->1 should work (you just can't allocate different textures to them).
There shouldn't be any continuity issues with the normals.
Check out the deep channel kernel in geometric normals and shading normals mode if you want to check out the normals in octane.
Hope that helps.
Chris.
Hope that helps.
Chris.
