This pc go well with Octane?
Sc4rfy
I've order a new pc (finally!!) :) :
Mother Board: Asus x58 i7 DDR3
Graphic card: Nvidia gtx480 1,5 Gb
Memory: 12 GB DDR3-1600
Processor: i7 930 2.8 Ghz 4.8GT
Power Unit: 850Watt
Os: win7 64
This pc is good for a fast render with Octane? Before i used a old notebook core duo with 9600m Gt
Win 10 64 Bit | i7 930 | 12 Gb Ram | GTX 760 |
radiance
that looks very good. octane will work nicely on it.
however i recommend you get a motherboard with at least 2 PCI-E slots on it so you can add a 2nd card if needed in the future.
Radiance
Sc4rfy
Thanks Radiance, the motherboard has 2 pci-e slots :)
radiance
i would consider adding a cheaper GPU then, as your primary GPU for display.
something like a GTX465.
this will give you a smooth use of your PC while octane is cooking on the GTX480, the windows UI will be responsive,
and when you do need the speed, you can always use both to cook 1,7x as fast.
Radiance
Sc4rfy
Yes, it's a very good solution :)
Many thanks for the suggestion Radiance :)
