OctaneRender® for Maya® beta 3.03d [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • Rework of how groups are rendered. Now the render-layers containing only groups should render objects included in these groups normally. In IPR mode the hierarchy of groups (transforms) which are changed is handled correctly now.
  • A little more improvements in particles compilation...
  • Check for object names uniqueness is added during render start.
NEW FEATURES SINCE LAST RELEASE:
  • Added the "Movable proxy animation" feature. So far just in test mode - it is not well speed-optimized so far, works for meshes only (Lights, Particles etc will be added later), and works only in IPR mode (other render modes will be supported in next versions).
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
Slimshader
Thanks Jimstar!
That demo looked great!
Can't wait to test this out.
jmfowler
Thanks Jimstar!
RayTracey
Wow, even deformable meshes update in real-time now :D .
Fantastic job Jimstar.
Q-Games
Thanks! 8-)
Intel Core i7-2600 CPU @ 3.40GHz | RAM 16GB DDR3 | GeForce GTX 480 Core 405 MHz | Win7 64bit Jap
RickToxik
Hey hey hey I'm super happy to be back for another Octane project.... And IT ROCKS!!! Boy that is fast. Fast with a capital FFffff.... lol
I have geometry instanced by particles in my scene. Is it possible to see them moving in the viewport like a movable proxy? The movable proxy option turned on (on the original object, I see no option for the Instance node) gives me an error and I can't launch the IPR when it's on.
But I don't care!
It's about 5000% faster than all other renderers! I just can't believe it. WOW!
Awesome work Jimstar.
RickToxik wrote:Hey hey hey I'm super happy to be back for another Octane project.... And IT ROCKS!!! Boy that is fast. Fast with a capital FFffff.... lol
Thanks.;)
It is not the full speed which is possible - so far I did not optimized the other things so scrupulously as particles...;) other, more important things, which should be implemented, take my time so far... But the additional, more scrupulous optimization will certainly be done, just in some of next versions...
RickToxik wrote:I have geometry instanced by particles in my scene. Is it possible to see them moving in the viewport like a movable proxy?
Yes sure, I wrote about it in the version description. Just in later versions.
RickToxik wrote:The movable proxy option turned on (on the original object, I see no option for the Instance node) gives me an error and I can't launch the IPR when it's on.
Strange, I just tried on my particle-scenes - no errors... Can you give the screenshot of the error, or the scene itself?..
charge
Can anyone tell me the way to set an Octane material node value (for example Specular) with MEL? I tried using setAttr but it gave me errors about the type.
Thanks.
Intel Core 2 Quad Q6600 (Kentsfield) @ 2.4ghz. Asus P5N-E SLI (nForce 650i). 8GB ram. 6GB Geforce Titan + 2GB GeForce GTX 560 Ti. Win 7 x64.
charge wrote:Can anyone tell me the way to set an Octane material node value (for example Specular) with MEL? I tried using setAttr but it gave me errors about the type.
Thanks.
//Set color pin value (Octane RGBspectrum Texture):
octane -tcp <pin name> <R-value> <G-value> <B-value>;
//Set float pin value (Octane Float Texture):
octane -tfp <pin name> <value>;
E.g.:
octane -tcp octaneGlossyMaterial1.Diffuse 0.96 0.17 0.346;
octane -tfp octaneGlossyMaterial1.Specular 0.451;
RickToxik
Hi!
There are two parameters in Octane for Maya that I'd like to know what they are meant for and how to tweak them, I've searched the docs and the forums but can't find anything yet.
-swatch quality
-dithering
Can someone explain them to me please?
Thanks in advance
Return to “Autodesk Maya”
