So the exporter plugin works perfectly with new scenes. And the 1.0 RC 3 seems to be fully compatible with the .ocs I have. If I open the .ocs in Octane, it renders just like it did originally. However, when I want to use the exporter plugin to update the scene geometry, it throws an error:
Softimage script editor:
// ERROR : 2000 - Argument 0 (Target) is invalid
// ERROR : 2001-GetValue - Argument 0 is invalid
// INFO : Starting RenderengineCode: Select all
There was an error parsing the command-line arguments:
Couldn't find match for argument Argument: E:\MyProjectPath\EcoAnim1.ocs
USAGE:
octane [-t <node name>] [-m <string>] [-r <filename>] [-l <filename>]
[-n <filename>] [--imager-exposure <float>] [--daylight-sundir-z
<float>] [--daylight-sundir-y <float>] [--daylight-sundir-x
<float>] [--cam-lensshift-right <float>] [--cam-lensshift-up
<float>] [--cam-aperture <float>] [--cam-focaldepth <float>]
[--cam-fov <float>] [--cam-motion-up-z <float>]
[--cam-motion-up-y <float>] [--cam-motion-up-x <float>]
[--cam-motion-target-z <float>] [--cam-motion-target-y <float>]
[--cam-motion-target-x <float>] [--cam-motion-pos-z <float>]
[--cam-motion-pos-y <float>] [--cam-motion-pos-x <float>]
[--cam-up-z <float>] [--cam-up-y <float>] [--cam-up-x <float>]
[--cam-target-z <float>] [--cam-target-y <float>]
[--cam-target-x <float>] [--cam-pos-z <float>] [--cam-pos-y
<float>] [--cam-pos-x <float>] [-q] [-g <int>] ... [-s <int>]
[--output-exr-tm <filename>] [--output-exr <filename>]
[--output-png16 <filename>] [-o <filename>] [--film-height
<int>] [--film-width <int>] [-e] [--] [--version] [-h]
<filename>
Where:
-t <node name>, --target-node <node name>
Name of the render target node to render
-m <string>, --mesh-node <string>
Name of the mesh node to render.
-r <filename>, --relink-meshnode <filename>
Load the given OBJ mesh file into the mesh node given with
--mesh-node.
-l <filename>, --link-meshnode <filename>
Create a new mesh node from the given OBJ mesh file
-n <filename>, --new <filename>
Create a new OCS project file from given command line arguments
Imager Exposure Amount
--daylight-sundir-z <float>
Daylight Sun Direction Vector Z Component
Daylight Sun Direction Vector Y Component
--daylight-sundir-x <float>
Daylight Sun Direction Vector X Component
Lens Shift Right
--cam-lensshift-up <float>
Lens Shift Up
Camera Aperture Radius
Camera Focal Depth
--cam-fov <float>
Camera FOV (degrees)
Camera Up Motion 2nd Vector Z Component
Camera Up Motion 2nd Vector Y Component
Camera Up Motion 2nd Vector X Component
Camera Target Motion 2nd Position Z Component
Camera Target Motion 2nd Position Y Component
Camera Target Motion 2nd Position X Component
Camera Motion 2nd Position Z Component
Camera Motion 2nd Position Y Component
Camera Motion 2nd Position X Component
--cam-up-z <float>
Camera Up Vector Z Component
--cam-up-y <float>
Camera Up Vector Y Component
--cam-up-x <float>
Camera Up Vector X Component
Camera Target Position Z Component
Camera Target Position Y Component
Camera Target Position X Component
--cam-pos-z <float>
Camera Position Z Component
--cam-pos-y <float>
Camera Position Y Component
--cam-pos-x <float>
Camera Position X Component
-q, --quiet
Start Application without splash and minimized window
-g <int>, --gpu <int> (accepted multiple times)
add GPU device to use for rendering (0 = first)
-s <int>, --samples <int>
Maximum number of samples per pixel (maxsamples)
Output tonemapped EXR image file when maxsamples is reached
Output EXR image file when maxsamples is reached
Output 16-bit PNG image file when maxsamples is reached
-o <filename>, --output-png <filename>
Output PNG image file when maxsamples is reached
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
Close the application when rendering is done
--, --ignore_rest
Ignores the rest of the labeled arguments following this flag.
--version
Displays version information and exits.
-h, --help
Displays usage information and exits.
<filename>
.OCS Project scene file
OctaneRender
