bedroom
MaTtY631990
Rendered with Octane3dsmax RC2 plugin. Pathtracing at 5000 samples for about 2 hours.
evo
wow, awesome work and very nice details!
The area of the mirror is great.
Just the falloff on the cushion look too strong maybe.
Intel Core i7 920 @ 2.67GHz, 6.00 GB, 896 MBGeForce GTX 260 (x2), Windows
RIBS_stairs
http://www.refractivesoftware.com/forum ... =5&t=17973
MaTtY631990
thankyou :)
HHbomb
Nice render , but i don't like windows aspect , to much CG
jmfowler
very nice, love the colour mixing that is happening, the falloff is a bit too strong - looks more like velvet than cotton.
The pure white coming from outside suggests there should be some aperture bleed happening around the curtains - which would be done post, so not sure if you wanted to just show a pure render here.
very good though!
Any reason why you chose PT instead of PMC? I find PMC is a lot more accurate for interior lighting.
MaTtY631990
Hi jmfowler, for me Pathtracing renders faster and give nice result for a scene such as this. There was not really significant benefit from using PMC. If had much more lighting, detailed caustics and lots more glossy/specular materials, I would definitely use PMC as it was born to that. Also your note about the bleeding from the curtains.
I have white diffuse material behind the curtains which is why you see all white from the window and no reflected red/purple color.
3rdeye
amazing details !!
User avatar (Default)
merid888
nice work, i like it, can you share settings ? time ?
regards
Proupin
I really like the images overall, but two things, one don't use filtering, It gets too blurry. Second, do not compress the images as jpg! This forum supports .png, and jpeg is really noticeable.
And maybe some levels to brighten it up.
MaTtY631990
merid888 wrote:nice work, i like it, can you share settings ? time ?
regards
both images took close to 2 hours each with Pathtracing.
