Large scenes (how?)
Molki
Hello,
I need advise, I have standalone version but I do not use it often.
But plugin for 3ds max is very perspective for me.
(i7,6gb ram, GPU 560ti 1GB)
Im trying demo plugin for now.
Example: scene with 5 trees (3 500 000polys) ,diffuse material (octane),octane camera,octane daylight. When render began : 1. Processing Geometry spend 7 minutes then started Rendering but after few minutes I still had black in render window.
I tried it with easier scene : Only audi r8 (500 000 polys) and plane but it was same.
But when I tried more easy scene :
One tree(1000 000polys) processing time was under 1min. and render time (relative)fast
I read that 1-2GB card is enought strong for - 3-4 milions of poly, but not for me.
1GB GPU is not enought ? or what´s wrong, I need use some special technique ?
I´ve got job, I will make and render long animation of cars and I need short render time per frame that´s reason for Octane.
Thing about better pc (i7 3rd generation , 32GB Ram, gtx680 4GB maybe 2x)
If I buy gtx 680 4GB with 1536 CUDA cores How it will work for example with scene : 20-30gb of RAM
Will it work good if it?
How can I do this large scene with GPU ?
I was looking for solutions or informations but I still don´t know nothing important.
Pleas, help me! :roll:
With respect
mikinik
hi. for my scene where 3 800 000 polygons were required 13 gigabytes of memory.
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
Molki
mikinik wrote:hi. for my scene where 3 800 000 polygons were required 13 gigabytes of memory.
So? it means that I need at least 13 gb Ram + stronger GPU ? or 13GB vRAm
mykola1985
13 GB RAM not video ram of course.
I have already tested octane plugin for 3ds max with different polycounts and textures.
My specs: i7 920 - 2,6GHZ. 12 GB RAM. GTX 580 1,6 GB.
For example without any texture in my scene, I can easily reach 7.500.000 polys to be rendered, even though the geometry update process reaches nerly 3 minutes. with heavy textures in my scene, octane eats all the video memory so I can reach max 2.200.000 polys. However octane is definiotely the best and quickest rendering engine
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
petergazo
Upgrading from 8GB to 16GB RAM solved problem for me.
i5-2500k | 16GB ram | gtx460 2GB (display) + GTX580 1.5GB | Win7 pro x64 | v1.0 beta 3.00b | http://www.behance.net/petergazo
JuM
with my 32gb ECC DDR3 Ram and gtx680 i rendered 560 Millons of polygon. the whole file is 1.3 billion but half of it is hidden.
Return to “Autodesk 3Ds Max”
