Hello.
I'm trying to adjust a scene with camera correction, but it seem to be not functional with octane viewport,
viewport correction is correct, but in octane render viewport or in standard render window, there is no correction
or very strange deformation of the picture.
How can I achieve my camera correction in Octane ?
Thanks.
camera correction not working
You need to use Octane Camera´s Shift option.
On the other hand,
as i pointed out in http://render.otoy.com/forum/viewtopic.php?f=27&t=23970,
Octane Camera Shift shows in the Render Window but not in the Max Viewport
On the other hand,
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
indeed, it is working differently than Max Camera Correction:
- Octane Camera Shift works like a Camera Shift in real life.
It does not straighten a distorted image but you set the Camera straight
and "shift" the viewing angle. hence the name "shift"!
it would be like applying a Skew modifier to a Max Camera
(it actually works. i used to do that before Camera Correction existed...)
- In Max it´s called "Correction" because its correcting the distorted image
- VrayPhysicalCamera uses the term "Shift" but this is not correct because
in fact, it is straightening a distorted image, too.
Check out http://en.wikipedia.org/wiki/Shift_lens for more info on that.
