With the debuginfo, you can check if the meshname/path is correct and other things.
The output should be similar like this:
// INFO : ////////////////////////////////////////////////////////////////
// INFO : // Debug Information ///////////////////////////////////////////
// INFO :
// INFO : Camera/s In Scene: Camera
// INFO : Light/s In Scene: light
// INFO :
// INFO : // Objects To Export////////////////////////////////////////////
// INFO : Meshes To Export: cube
// INFO :
// INFO : Camera To Export: Camera
// INFO :
// INFO : // Parameter To Export /////////////////////////////////////////
// INFO : cCam: --cam-up-x -0.243231 --cam-up-y 0.945345 --cam-up-z -0.217168 --cam-target-x -8.88178e-016 --cam-target-y 4.44089e-016 --cam-target-z 8.88178e-016 --cam-pos-x 4.64446 --cam-pos-y 2.14761 --cam-pos-z 4.1468 --cam-fov 53.638
// INFO : cImage:
// INFO : cSamples:
// INFO : cMesh: -m test2_.obj
// INFO : cLink: -r "C:\Users\face\Desktop\Project\test2_.obj"
// INFO : cLight:
// INFO : cNew:
// INFO : cFilm:
// INFO : cOcs: "C:\Users\face\Desktop\Project\test2_.ocs"
// INFO : cLens: --cam-aperture 1 --cam-focaldepth 5 --imager-exposure 1
// INFO : cGpu:
// INFO :
// INFO : cPara: -m test2_.obj -r "C:\Users\face\Desktop\Project\test2_.obj" --cam-up-x -0.243231 --cam-up-y 0.945345 --cam-up-z -0.217168 --cam-target-x -8.88178e-016 --cam-target-y 4.44089e-016 --cam-target-z 8.88178e-016 --cam-pos-x 4.64446 --cam-pos-y 2.14761 --cam-pos-z 4.1468 --cam-fov 53.638 --cam-aperture 1 --cam-focaldepth 5 --imager-exposure 1 "C:\Users\face\Desktop\Project\test2_.ocs"
// INFO :
// INFO : // Softimage To Octane Exporter v2.2 2010 Stephan Woermann //
// INFO : ////////////////////////////////////////////////////////////////cImage: The image path and name.
cSamples: Number of samples.
cMesh: Name of the saved mesh.
cLink: Name and path of the linked mesh.
cLight: Light direction for sunlight.
cNew: Name of the scene when you create a new one or use the option "Overwrite existing"
cFilm: Film x/y resolution.
cOcs: The existing ocs-file.
cLens: Lens options for aperture, fdepth and exposure.
cGpu: GPU´s you use.
cPara: The commandline which is send to Octane.
Some of these parameters are shown, when you click the "Render Animation" button.
[vimeo]http://www.vimeo.com/12742533[/vimeo]
