Currently I am converting my RVT file into an FBX and the using the Autodesk FBX converter to convert the, before mentioned, FBX into an OBJ file. This is causing me a couple of problems because the models comes out with the wrong AXIS configuration. With this I am trying not to use 3DS MAX or any other modelling program to get my REVIT models into OCTANE. the steps I would like to use would be:
1. REVIT
2. FBX CONVERTER
3. OCTANE
Can anyone help me, sorting this out will help me decide if I buy OCTANE RENDER or not.
Exporting From REVIT Architecture
Then please keep me posted because as I said this does influence greatly my buying decision, anther question is when will the glass material be up and working, at the moment it doesn't render properly because it doesn't let any light through and as I use 3D mostly for architecture visualizations this is also quite important, and finally ill the materials become more complete like mapping and falloff, self illumination, artificial lights etc... because yesterday I was trying to apply a map of a logo on a material and I couldn't seem to rotate or do anything besides scaling. Please don't get me wrong I think that Octane Render is one of the most amazing programs to have hit the 3D World, the entire Octane Render team is to be congratulated because the program in terms of render times is amazing but I do need to know what the progression of the program is going to be material wise and what ever you may think is relevant so that I can consider wisely the investment in the program and a good graphics card
Thanks for your time and again congrats on a brilliant program and I hope it develops to be a leader in the market.
Quaresma
Quaresma
Quaresma
- jbnarch925
Ive heard glass needs to be a flat plane with no thickness. This is why alot of people use 3ds to select all glass in the model and flattening the thickness.
I have thesame problem.
I tried RVT > DWG > Sketchup and than render in octane - unfortunately there is a loss of materials.
Revit import in Blender didn't work at all for me. I'll try a simpler model.
I think there would be plenty of potential customers if there was simple import from revit. In-built renderer is easy but not satisfying.
