Computer freezes while rendering video animation
eagle1986
Hey folks,
I've problem with rendering a videoanimation with the OctaneRender plug-in for 3ds Max 2013. Everytime when I start rendering the first 10 pictures of the video get rendered well and then the computer freezes. :|
Has anybody the same experience with the OctaneRender plug-in (Version 3.03)?
I've already checked RAM and temperature, but there is everyhting ok with this. :roll:
Thank you in advance!
Win 7 64 | 3x NVIDIA Geforce GTX 580 | Intel Core i7 3820 3.6 GHz | 32 GB
HHbomb
with a test scene, i have no problem (3.03)
I had a problem one day : chamfer a flat object with glossy material that make faces overlaping (or worse)...
octane render try to render the image (hours) but can't (just black).
3form
Yeah same problem renders fror like 5 to 10 frames then 3Ds max crashes :evil: on PMC and DL any ideas?
Cheers
J
GTX670 4GB, GTX460 2GB, Q8400 2.27Ghz, 6GB RAM
njam
I'm also getting the same issue with RC1a on Max 2013 X64 with PU5.
Max crashes after the 6th frame (regardless of whether it was rendered as images or as an avi).
Has anyone been able to solve this?
Ned
Karba
njam wrote:I'm also getting the same issue with RC1a on Max 2013 X64 with PU5.
Ned
What temperature do you have after 1st frame and after 5th frame?
What GPU and power supply do you have?
njam
I've got two GTX580 3GB's and a 1200W power supply.
Not sure about the temperatures - they're less than 60C but I'll check on that.
Return to “Autodesk 3Ds Max”
