OctaneRender® for Maya® beta 3.03 [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • It seems that "not smoothed material wrong normals" bug is fixed in new engine...
  • SynSky node transform is named accordingly after SunSky node is created.
NEW FEATURES SINCE LAST RELEASE:
  • New engine 3.03 version with Kepler support (previous GPUs are supported too).
  • "Movable proxy" attribute is added to Meshes and Octane Light nodes. Now by default all scene geometry (including particles and instances) is loaded to octane engine as one common big mesh. It improves the renderspeed very much, but raises the GPU memory consumption and voxelizing time (in the case of particles or instances are present). If you set the "Movable proxy" attribute - this mesh (and all its particles and instances) will be loaded to the engine as separate mesh. It will lower the GPU memory consumption and voxelizing time (in the case of particles or instances are present), and lower the render speed. And in next version it will let to load this mesh separately during the IPR session, so you will not need to reload full scene geometry when changing this "Movable proxy" mesh.
  • Triangles count and Meshes count are added to render statistics info.
  • Added sliders to Octane Sun direction attributes.
KNOWN ISSUES IN THIS VERSION:
  • "Partial scene refresh" in IPR mode will be added in next version: I just want to release this version as fast as possible for those who already have Kepler cards and can't use previous versions at all...
  • The strange "low light" issue still exists. As I found - the power of light is cut if the emissive object is loaded as "Movable proxy", other words "as separate object". If it is loaded the "old way" (as part of common mesh) - it has the same power as in 2.58 branch. I already posted the question to engine developers, trying to find the reason of it, and I will release the fixed version immediately after the reason will be found. So far, you can just not set the new Movable proxy attribute in Octane Light nodes and emissive Meshes, or play with ISO or exposition in Imager...
DOWNLOAD
New version HERE.
Yours,
The OctaneRender™ Team.
TBFX
Thanks JimStar! I've quickly tested everything mentioned above and all seems good. I think we now have a useable version of the 3.xx branch.
Awesome work!
T.
RayTracey
JimStar wrote:And in next version it will let to load this mesh separately during the IPR session, so you will not need to reload full scene geometry when changing this "Movable proxy" mesh.
Awesome!
jmfowler
THANKYOU JIMSTAR!
Q-Games
Fantastic news! Thank you JimStar! 8-)
Intel Core i7-2600 CPU @ 3.40GHz | RAM 16GB DDR3 | GeForce GTX 480 Core 405 MHz | Win7 64bit Jap
Refracty
thank you.
Great release.
There is a small bug with the color slider.
Lets say you apply a RBG spectrum node to a glossy / specular input. Then you assign a red color for example. If you pull the color slider to the left it gets black as expected but if you pull it back to the middle the color is gray and not red like it should be.
Refracty
I have a scene that keeps on crashing. Unfortunately I can not give away the scene for NDA reasons but is there a other log file somewhere that I could hand out to you JimStar?
Refracty wrote:I have a scene that keeps on crashing. Unfortunately I can not give away the scene for NDA reasons but is there a other log file somewhere that I could hand out to you JimStar?
After the crash you can look into the directory c:\Users\<User Name>\AppData\Local\Temp\ for the last files MayaCrashLog*.dmp and MayaCrashLog*.log. These will be very helpful.;)
And you can enable Octane verbose mode, open the script editor (if you can do it before crash), and take the screenshot of its content after crash. It may be helpful too...
About color slider issue - I will check it, thank you!
Hatak
Hi Jim!
About color by speed, age and ect.
It is not implemented so far...
It is you work or Octane Team? (:
Can you ask me how to do it, not for octane? May be for lambert material or blinn? (: Thanks! I mean, when I do box or any poly object is instans for nParticles
Thanks! (:
My english is bad. Sorry D:
Dual Core E6700 3.2Ghz | GTX 580 | 4gb ram | Win7 64 |
Refracty wrote:There is a small bug with the color slider.
Checked it.
It is the Maya's bug in its UI color control. Just try to create standard Maya's "lambert" and play with its "Color" attribute... You will get the same...
I will try to hack it some way later (I think I know how to do it), added it to my TODO...
Return to “Autodesk Maya”
