Octane exporter for C4D version 0.08
abstrax
Hi all,
Here comes version 0.08 of the Octane exporter for CINEMA 4D.
What has changed?
- I added the export of the sun light direction. By default the first light object with a sun expression it chosen.
- I added the export of the GPU settings. You can specify there the GPUs you want to use as a space separated list of GPU IDs (starting with 0 for your first GPU) - similar to the settings in the device manager of Octane.
- I also changed the camera drop down list: The first entry is now always "Current Render Camera", followed by the names of the actual camera objects. If you select "Current Render Camera" that camera gets exported that CINEMA 4D would use for the particular frame. The stage object will be evaluated, too.
- I added two more entries to the pixel sample drop down list: "Medium/Low 128 s/px" and "Custom". If you select "Costom" you can specify any threshold you like in the edit field right to the combo box.
I hope everything works fine.
These are the PC builds of the plugin:
CINEMA 4D R9.6 (32/64bit):
OctaneExport_0.08_win_r9.6_release.zip
(175.87 KiB) Downloaded 450 times
CINEMA 4D R10.1 - 11.0 (32/64bit):
OctaneExport_0.08_win_r10.1_release.zip
(176.46 KiB) Downloaded 486 times
CINEMA 4D R11.5 (32/64bit):
OctaneExport_0.08_win_r11.5_release.zip
(255.63 KiB) Downloaded 574 times
These are the Mac builds of the plugin:
CINEMA 4D R9.6 (32bit):
OctaneExport_0.08_mac_r9.6_release.zip
(114.75 KiB) Downloaded 453 times
CINEMA 4D R10.1 - 10.5 (32bit):
OctaneExport_0.08_mac_r10.1_release.zip
(152.27 KiB) Downloaded 445 times
CINEMA 4D R11.0 (32/64bit):
OctaneExport_0.08_mac_r11.0_release.zip
(318.76 KiB) Downloaded 475 times
OctaneExport_0.08_mac_r11.5_release.zip
(348.62 KiB) Downloaded 503 times
Happy rendering,
Marcus
mat536
Thank you very much!
Mark
Core i7 920 - 2.67 GHz | Win 7 Pro 64Bit - 12 GB RAM | GTX275-896MB - driver v.197.45 | 150 GB Raptor 10K HD | Octane 1.022 beta 2.2 |
Vincent
Thank you so much Abstrax ! :)
Win7 x64 - Intel Core i7 920 (2.67 GHz) - Geforce GTX 285 - 12Go RAM
www.wipix.fr
clement
thx Marcus !
Win7 x64 / Cinema4D R15.064 / I7 4930K - Nvidia gtx770
katerlake
Thanks. With C4D R10 it works without any problems. More can i say after some tests.
thanks a lot. Good Job.
|Q8400, gtx770 4Gb |12 Gb Ram|Win7 64 Bit|C4D R15 Visualize and Octane
my 3D-Blog: http://katerlake.blogspot.com
my Vimeo: http://vimeo.com/user4046032
my FlickR: http://www.flickr.com/photos/45536398@N05/
ilanb
Thanks !
MacBook Pro | OS X 10.6.4 (10F569) | GeForce 8600M GT 512Mo | IntelCore 2 duo 2.5GHz | DR2 SDRAM 667 2go*2 | C4D 11.5+octane | Cuda Driver 3.00
Vincent
www.wipix.fr
lassinger
Big Thanks from me too!!!!!!
http://www.larsnaglerworks.com
http://www.behance.net/LarsNagler
http://cargocollective.com/larsnaglerworks
Mac Pro 5.1 :: 3,33 GHz 6-Core Intel Xeon :: Mac Pro Nvidia GTX680 4 Gig :: 32GB :: C4D 13 Studio :: Octane Renderer
OP-1
ribrahomedesign
thanks markus
works well so far .
2 questions :would it be possible to runn octane in the backround whiles is rendering a animation,if
I click to minimize the octane screen ,every time it loads a new frame it comes back to the front of the screen
its disturbing when you want to do something else at the same time.
when i select 2 GPU to render a animation ,the Dof is changing ,i dont know but thats maybe a octane bug
thanks for your fantastic and fast work
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
abstrax
ribrahomedesign wrote:thanks markus
works well so far .
Hmm, I'm trying but didn't get it done on Windows yet. Octane is always grabbing the focus although I launch it with the cmmand line parameter "-q". I'm looking at a solution to give C4D the focus back, but wasn't successful yet.
Rico
If you open the console window, you can see the command line I use to launch Octane. Could you please copy and paste it into a PM? Maybe I'm doing something wrong.
Marcus
