OctaneRender® for Maya® beta 3.0c [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • The FloatTexture bug workaround.
  • Fixed the bug when "multiple objects" particles rendered with only one object.
  • Added "no geometry in scene" workaround when starting render.
  • Fixed environment texture disconnection bug (RickToxik reported).
KNOWN ISSUES IN THIS VERSION:
  • The meshes collapse is not optimized so far, so the render speed may be slower than in 2.58 branch.
  • Strange normals issue when rotating objects connected to non-smoothed materials still exists...
  • Multithreaded voxelizing is still disabled...;)
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
jmfowler
Jimstar - my lights are rendering extremely dark in this update - see image
I have a combination of IES and mesh emitters plus an open wall with a low environment colour bleeding in. Normalize is turned off on all my lights and when I switch them on in this patch it makes it slightly brighter but only just a bit.
Anyone to comment --> On a side note - As i understand what a normalize function does - it should not be on for an animation to avoid flickering correct?
cheers,
TBFX
jmfowler wrote:As i understand what a normalize function does - it should not be on for an animation to avoid flickering correct?
I believe in Octane turning normalize on for an emission simply allows you to change temperature settings without altering the intensity, were as normalize off will mean a temperature of 12000 will be a lot brighter than one of 500 at the same power setting. It shouldn't make any difference to flicker in an animation.
Nice render by the way.
T.
jmfowler
normalize - Ah ok T. thx for the info, - Have you tested this build? - were your lights affected like mine?
TBFX
jmfowler wrote:normalize - Ah ok T. thx for the info, - Have you tested this build? - were your lights affected like mine?
Yes, just tested now and black body emitters are very dark on original settings. I can increase their power and it has an effect but no where near enough, something is definitely not right.
T.
Strange...
I just take the scene which TBFX has sent (as the previous light bug example), open it with 3.0c:
And then open it with 3.0 and render with the same light settings (except I had to move a slider back and forth to eliminate the fixed in this version bug):
As I see - the power of light is the same in this 3.0c and in previous 3.0...:?
TBFX
Ah, now I get why I had to have the light so bright in that scene. The difference is between the 2.58 branch and the 3.0 branch. Open that scene in 2.58q and see what happens.
T.
TBFX wrote:Ah, now I get why I had to have the light so bright in that scene. The difference is between the 2.58 branch and the 3.0 branch. Open that scene in 2.58q and see what happens.
T.
Yes, with 2.58q I see the difference. I just was misled by this "my lights are rendering extremely dark in this update" - I thought is was some bug in this new version of this 3.0 branch...
Now I see that it is rather not the plugins problem - plugin gives to Octane engine the same values in both 2.58q and 3.0c versions...:? So, I think it's just may be some changes in the 3.0 engine...
jmfowler
sorry I should have been clearer - ( I realize that there's a current workaround with 3.0c - I just wasn't sure why the light intensity was so vastly different from 2.58)
for my scene - with such a massive difference in light intensity, should I increase cameras exposure/ISO? or increase the lights intensity? ( if I change camera I will get too much environment light? )
TBFX
JimStar wrote:Now I see that it is rather not the plugins problem - plugin gives to Octane engine the same values in both 2.58q and 3.0c versions... So, I think it's just may be some changes in the 3.0 engine...
Hmmm, the standalone versions don't have this difference. Tested in 2.58 and 3.0 standalone and the results look the same.
I guess it must be the sdk version with the problem.
T.
Return to “Autodesk Maya”
